Results 1 to 10 of 18
Thread: NEW LS2 6.0L Crate Engine
    GLENDALE,ARIZONA
    I have a NEW LS2 6.0L GTO Crate Engine up for sale. I got this engine at A GMPP auction and was told it was in the Chevy Dealer Parts Department for a while when the parts guys robed the Water pump and exhaust manifolds from it. To sale them to a customer "Who Was In Dire Need Of Them", and they were going to order new but never did. And once they take off parts they cant sell it as new. I don't know how true that is, but I did have the engine gone over by my machine shop from top to bottom. They found that the engine has not been fired and it is in Brand Spanking new condition. The Engine has 243 heads with Hollow stem Intake valves and sodium filled Exhaust valves rated at 400hp. the part # is 19156261
    I'm asking 4,500.00 Plus Shipping for it. You will get what is in the pick. No Warranty due to the nature of the engine and its purpose lol
    I also picked up a 6.2L All Aluminum Long block 823 heads, and 3 5.3L all Aluminum Long Blocks with 243 heads, I will be having the Long Blocks Rebuilt and Gone Over.
    Let Me Know If You Are Interested in one.
    UPDATE!! I just got with my GMPP rep and for $1,800.00 extra I can get the LS2 Controler Kit & Serpentine Accessory Drive System, with Air Conditioning this includes the following:
    CONTROLER KIT
    Includes Computer, Harness, 02 Sensors, all the crap to run your New LS2.
    SERP DRIVE SYS
    Fits LS2 and LS7 engines
    Deluxe kit includes all the components and hardware necessary to install on an engine with air conditioning, including alternator, power steering pump and idler bracket, (belt included)
    The system includes:
    12579229 Belt (water pump, alternator, and power steering)
    12585476 Belt (A/C compressor, LS7)
    12569301 Tensioner Assembly
    12595289 A/C/ Belt Tensioner Assembly
    12568996 Idler Pulley
    88958093 A/C Compressor
    12569286 A/C Compressor Bracket
    15261472 Power Steering Pump (reman)
    26046502 Power Steering Reservoir
    12578067 Alternator and Power Steering Pump Bracket
    12555693 Power Steering Pump Brace
    12568997 Power Steering Pump Pulley
    15841234 Alternator
    12579228 Belt(A/C compressor, LS2)
    GLENDALE,ARIZONA
    More Picks
    Nov 2009
    Tucson,AZ
    How much for the ls2 short block?
    chevyboy.520
    06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
    PRC stg 2.5 5.3 heads Awaiting to go on!
    GLENDALE,ARIZONA
    Talking
    Quote Originally Posted by chevyboy.520 View Post
    I can get you a LS2 short block with all new ballanced internals for around $1,700.00 plus shipping, I dont have all used LS2 short blocks at this time, Just the one and the block had 15,000 on it prior to the New internals. I can get you a New set of LS3 heads complete with a New LS3 intake complete with injectors, rails, TB, and cover to go with this LS2 for 1,300.00 extra.. lol Thats 3k for a bad azz set up.. Just sayn..lol
    Thanks
    Michael
    Here are some picks of when we went over the LS2 to make sure it was legit.... The small amount of oil you see was from when we checked to make sure it built pressure and the compresion was on the $$$.. this sucker is sweet!!!! Whoever gets it be warned I did fondle it.lol It is now a Molested LS2..lol
    GLENDALE,ARIZONA
    heck you are in AZ no shipping lol you can pick up.
    Nov 2009
    Tucson,AZ
    And how much for the 6.2
    chevyboy.520
    GLENDALE,ARIZONA
    I dont know on the 6.2L until I get it to the shop for inspection, After the rebuild im thinking $2,800.00 to 3,000.00 with a new LS3 intake with inj's rails, and TB. Or The truck intake with all the fixn's as well.
    Nov 2009
    Tucson,AZ
    That would be a good set up and a good price! Any way you can get a lq4 or lq9 or even ls1. I'm gunn a use my PRC 5.3 stg2.5 heads and my fast Lsxrt 102. So i guess 6.2 is out, and a ls2 would bump my comp up pretty high with these heads
    chevyboy.520
    GLENDALE,ARIZONA
    Ill see what I can drum up I do have a 2002 LS1 I need to go over it everything spins freeley but i havent dropped the pan yet to check it out, I will reman it and look to get 1,800.00 out of the short block once rebuilt, this includes ballancing, line hone, rings, bearings, well you get it. lol
    I can get 6.0L iron block,s as well. ill check on them, all my engins are GM take outs so I pay good $ for them and have yet to have one with major isues like spun rod bearing and such.
