Results 1 to 10 of 14
Thread: Gear ratio for Turbo aplication !
    Mar 2007
    Help me beat some more this dead horse !
    For what I read and know, lower gear ratios are a no-no for boosted aplications.
    Lot of reasons here, but the one most builders tend to point out is loading the engine in order to make boost.
    And the other main reason tends to be traction.
    If we go to basics of 1/4 mile, we want to pass in the shortest time posible.
    If we have a drag dedicated car, we will want to pass 500-1000rpm before hitting the rev limiter 1:1
    Now, if we have a 4wd drag car, that has non to minimum tire spin, and because of it's weigth (4500lbs) and the resistance that all the drive line puts to the engine.....will it load the turbo?
    Top this with the long 1st gear from the 80e.
    And pretend the gear change is minimal, like 3.73 to 4.10
    Will this gear ratio swap give lower ET's ?
    Oct 2007
    Bandera, TX
    i think so. I think too high of a gear is still hurting you even with boost. I love my 3.70 gears. and would not even consider going higher, I would go lower if anything. as long as it makes the desired boost, it is loading enough imo. just my .02
    single digit street truck
    for build info
    ill sell u some 3.23s oem haha
    Mar 2007
    I'm still in denial !!!!
    I'll wait for 04chase to swap to 3.73 from 4.11
    He has some good times on 4.11 awd
    Let's see if the higher gears will make a positive difference !!!!
    Mar 2007
    Newark, Delaware
    Subscribed. I'm trying to figure out what gears to run in my turbo 5.3 w/80E. 4.10's combined with the 80E 's 2.48:1 first gear is equal to "3.32's" and the 60E's first gear. I just want to make sure the truck will pull a decent 60' time.
    Big slow mud truck with a TUNE!!!!!!
    Pittsburgh, PA
    with the 5.3 the 410s should work well
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
