Results 1 to 10 of 12
Thread: Exhaust Cut Out Electrical Question
    So Cal
    Today im going to be installing the electrical to make my cut out useable, the cut out is from Racereadyperformance.com i was to much of a cheap ass to by the harness so i bought some cheap things at radio shack...
    2 Relays
    Some connectors
    Lots of wire
    3 way switch (Open , Neutral, Close)
    the one thing i can not seem to figure out is how to hook up the relays to revers the polarity to close, then to open
    Heres what i got...
    Thanks Guys for all your input
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Mar 2006
    Mesquite
    I had mine on a hold/open hold/close switch. No relays or anything. Just power and ground.
    Round Rock, Texas
    A momentary 2 way switch is the best option but you have to hold the switch. You could get fancy and build a timing circuit that you toggle one way and it opens, then toggle the other to close.
    So Cal
    thats basiclly what i have ill take a picture of the switch tomorrow so you can see what im talking about
    So Cal
    Found this online just now basiclly what i was i was thinking of doing, correct me if im wrong but do my relays have (87a) for ground? will these relays work? if not i have one other one that does but im not to sure where to find a matching one at
    Round Rock, Texas
    That diagram will work, but you have the wrong relays. Just remember to move the switch back to the center position or you will burn up the cutout motor very quickly.
