Results 1 to 10 of 10
Thread: When to wet sand?
    Mar 2008
    Burleson, Texas
    When to wet sand?
    I am getting ready to repaint my SS bumper and want to get the best results possible from a spray can. I did some mirrors a while back with primer, then a couple coats of color, then wet sand and buff and they turned out pretty good but this time I want a better shine. Should I do the wet sanding before or after the clear? Or both? I don't know much about paint.
    '00 Silverado 4.8L (Gone)
    '11 Silverado 4.8L
    Quote Originally Posted by RUFFNECK View Post
    ...First relieve the pressure before doin' that or else you will get a nasty squirt and may get in ur eye.
    Jun 2010
    baxley,ga
    Quote Originally Posted by yournamehere018 View Post
    water sand it with 400grit real good.dry it off when finish.clean it with wax and grease romover then 2 coats of paint.10 mins between coats.then 10 mins after 2nd coat put a coat of clear on then wait 10mins then put last coat on.you get the idea.i never painted a truck with a spray can but thats the way a body shop would do it.after it dries,you can cut and buff it.this will make it real slick and get trash out if any.water sand it with 1000grit then 2500grit.then buff
    04 rcsb forged 347
    Mar 2008
    Burleson, Texas
    Ok cool thank you! I just didn't know if wet sanding before the clear would achieve a better result or just make it harder for the clear to stick.
    '11 Silverado 4.8L
    Jun 2010
    baxley,ga
    don't sand it before you clear it.after you clear it and it dries instead of cuting and buffing it you could sand it with 1000grit then reclear it again.either way you want to do it.btw if you cut and buff it becarefull and not burn threw the paint
    04 rcsb forged 347
    Jun 2004
    In a van down by the river- MD
    I agree to sand it before paint, however , I think 400 is a lil ruff. I would start by hitting it with 5-800, just to haze it, open up the plastic some.. Then wipe it down good with alcohol, paint thinner.. If you have a tac cloth that will work after you clean it with the cleaners.. Paper towels work extremely well also.. Spray it with the paint your going to use.. Do however many coats you feel you want to do. Make sure it is even, spray the next coat while the previous coat is still tacky.. Once you have finished that, let that tack up, hit it with clear. Do the clear the same way as you do the paint, for however many coats you want.. Then once that has dried, hit with 2000 paper, water.. Go even with the strokes, keep the paper wet.. Then you have to buff it.. Buff if on low speed like 14-1700. Do not get it hot, always pull away from the edges.. Use a super super fine or even a finish cut.. Spray paint clear is a little softer then the good stuff.. I have done out board engine covers, valve covers, all kinds of things with rattle can paint it has turned out like a job I have done out of a gun. Prep is key to painting, not rushing through it.. vIf you would happen to get a run, let it dry and just sand that area out, then hit it with another coat of paint or clear.. Prep and finishing is where it as. The stuff in between can be persuaded some
    JOHN
    Jun 2010
    West Texas
    Quote Originally Posted by Mangled03gmc View Post
    +1
    RUN WAT U BRUNG!!!!
