Thread: Best Throttle Body (cable) for LS6 manifold?????
    Mar 2007
    I have a BBK 80mm that is leaking air on the side of the moving shaft.
    Want to replace it, but want to go for a better bigger one. (3 bolts, Cable)
    what will be my options on the market?
    Jan 2005
    Humble/Houston TX
    i have a ported, filled/drilled half shafted, and bump stopped stocker that i will sell. 80 takes it. it's professionally ported (ie: i didnt do it lol). you can read about it online. google shaners throttle body. it's the S2.
    old mod list: H/C/I/N/E/G 408
    Mar 2007
    I researched on Shaner's work, and everyone says it's awesome.
    will a 4 bolt TB with some machined work fit my 3 bolt manifold?
    I want something 95mm plus !!!!
    Jan 2005
    Humble/Houston TX
    Quote Originally Posted by 2boostedSilverado View Post
    what manifold are you running? a 95mm throttle body is useless if the throat of your intake is 78mm.
