Results 1 to 10 of 10
Thread: Rear mount guys, take a look
    The Garage
    This thread is for every guy who has ever blown a turbo, only to find oil in the intake pipes. First of all, and most importantly, the oil drain line. In this case, size DOES matter. I blew oil past the turbo's seals multiple times when I had the STS oil drain setup and I have had no issues since I incorporated this drain setup with AN-10 line. The point of having the big drain line is to use gravity to allow the oil to drain freely, and without restriction, out of the center section. This prevents the oil from pooling up in the center section and pushing past the seals. A 90* fitting on the drain may not be the best idea, but notice how I allowed 4" of pipe from the center section as to allow the oil to pool up in the line underneath the turbo, rather than inside the turbo - then the pump takes over. BTW, only use the ExaPump for oil scavenging because it is quite simply the BEST pump for oil scavenging, period.
    Second, is the oil restrictor. Most people do not understand how common over-oiling a turbo is. STS seems to think that a wide-open AN-4 line, without a restrictor, and with about 60psi of oil pressure @ WOT will not harm the turbo - Those idiots are WRONG. Most turbos need an oil restrictor and the size of which will vary from turbo to turbo. For example, I run a journal bearing 60mm and I use a 0.065" restrictor which is a tad big for that turbo though - a 0.050" would probably be better. Notice in the picture how the restrictor is mounted prior to the 90* fitting. This allows the restricted oil to hit the side wall of the 90* fitting, then trickle down into the center section thus providing a gentle flow of oil. If you install the restrictor directly into the center section, you will have a pressurized jet violently spraying the center section with oil which I think could be bad.
    Last, but still important, the PCV setup. Like an idiot, I believed the STS PCV setup was sufficient at first. I then realized it chokes the crankcase trying to vent it through one tiny orifice. I also tried putting filters on the valve covers, but I found oil was making its way out the filters and on top of the valve covers - no bueno. Finally, I installed a moroso breather tank. It is a very simple installation and setup which works very well - crankcase doesn't choke @ WOT, valve covers don't get saturated with oil, etc. If the crankcase gets choked @ WOT, your oil pressure will skyrocket and the turbo will probably give. Installation is simple - just mount the tank and run hoses from it to the valve cover nipples.
    ~ Forged engine of some type ~ Ball bearing turbo of an unconfirmed size ~ 4L8000 trans ~ Beefy fuel system ~
    The Garage
    More pics. BTW, the oil restrictor is the orange fitting.
    Nov 2006
    Quote Originally Posted by jetmech View Post
    In the last picture to the right of the second post is that a filter before the restrictor?
    60lb Multech II Truck Injectors
    2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
    2004 Dodge Ram SRT-10 - Silver
    2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting turbo
    The Garage
    Quote Originally Posted by SRT10KLLR View Post
    No, it's a check valve. It just stops oil flow into the turbo when you kill the engine
    Pittsburgh, PA
    not all turbos even need a restrictor. restricting a turbo can harm it just as well as over oiling it. some setups are using -6 as an oil feed with no restrictior but also using -12 as drain.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    The Garage
    Quote Originally Posted by Quik View Post
    Interesting. Not saying you're wrong, but in my experience the oil restrictor has always been needed. I figure that restricting oil flow too much will sieze the turbo while over-oiling it will just push oil past the seals but still allow the turbo to spin. Over-oiling has happened to me a few times How big are the turbos with -6 feed and -12 drain? I'm assuming they're pretty big.
