Results 1 to 10 of 19
Thread: 92 Silverado 5.3/60e conversion
    May 2010
    so cal.
    So this truck started out as a 4x4 K1500 with a 5.7tbi and a 700r4 trans. It is now in the process of being converted to a 2x4 1500 with a mildly built 5.3 and mildly built 4l60e. These were both pullouts at a junkyard out of an 04 Avalanche. The reason for the 2x4 conversion is the cost of an adapter to use my 241c tcase with a newer model 60e. And the pullout of the Avalanche was a 2x4 so I would have had to also convert the trans to 4x4. It just started adding up quick and I'm on a budget...sort of.
    So the mods to this 5.3/60e are this:
    2004 5.3 lm7 with 80,000 miles
    TR220/220 112 lsa
    Comp 918's/hardened pusrods
    Vette Filter/EP381 pump
    Schoenfeld lt's
    ls6 intake
    Custom HPtuners tune by a friend of mine
    Custom cold air intake
    Ls1 electric fans
    Transgo HD2
    Circle-D 3000 stall
    B&M cooler and deep pan
    Autometer Gauges
    Well I started taking pics kind of late so I apologize to you guys for that. Started out by tearing the engine down to a short block to check it out and install the cam and springs. It looked great still showing the hash marks in all 8 cylinders.
    Next we installed it in the truck as a long block so that I had room to mount radiator/fans
    Here's a few teasers:
    I will do my best to update this with as many pics as possible. Next is the accesories and then the wiring harness.
    SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
    Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
    2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
    May 2010
    so cal.
    Figured I post a couple more pics....
    This is what is getting the swap....yes I know the paint sucks I am planning on either red ot flat black.
    This is my tuners goat that I have been working on. Fixed blown head gaskets.
    It's got:
    Katech LS7 7.0 427
    STS rear mount
    FAST Intake/bigmouth
    Makes about 1000hp at the rear wheels on 9 lbs.
    And lastly is the Dmax
    PPE HOT 350hp tuner
    Banks turbo back
    AFE CAI
    Built Allison
    Makes 527hp and 972 ft. lbs
    Gramercy
    wow....holy crap thats some cool toys man.
    also Flat black is the way to go with a cowl hood...sweet!
    that cam/converter set up is going to be fun. what gears are you going to run? 3:73s or 4:10s
    2008 GMC CCSB 6.2/6L80e swap
    May 2010
    so cal.
    Quote Originally Posted by keniff View Post
    Thanks. The GTO is a scary mofo to drive on the street with those tires. I'm leaning more towards the flat black with a 2" cowl....Also the truck has 3.73's and a G80 so I will probably stick with that for now.
    May 2010
    so cal.
    Update
    Okay So i got a few more things done on this build. Installed fuel pump in tank, installed shift kit, and installed accessories and headers on the motor. The headers will be ceramic coated but I wanted to build exhaust. I still need to do the wiring and order my stall after pay day.
    Here's a few pics
    gonna be following this thread as I am starting to jump into the same boat. What are your plans for AC, would a stock 98 vortec fuel pump work for this motor? Stock 34" Radiator work?
    Gramercy
    if i was you to save on cost, run the stock 350 radiator and over flow tank with efans. i spent 250 on my efans an harness another 100 on JUST the jug another 20 on the cap and they wanted 100 for the hose with the Y in it for the jug, water pump, heater hose. i i was to do it again thats the way i would have gone.
    as far as the fuel pump, yes a stock replacement will work but i spent the 200 on a Walbro 255 with hot wire kit vs a stock fuel pump. just my .02
    3:73s will be good, im going 4:10s anyways! i need the gear to make up for the lack of converter (its a 2600-2800) im not willing to pull the tranny just to restall it. besides, its just a DD lol
    Gramercy
    also, you run a Josh Powers custom A/C bracket, itll allow you to run your factory 88-98 A/C
    im running a stock crank pulley, Truck Acc, my AC pump. i used 2 idler pullies bc i didnt have access to the right belt at the time. i used my 4.3 tensioner pulley (its a smooth pulley) next to the AC pulley, i then bought another idler pulley for an 04 5.3 to use on my tensioner by the water pump with a 1090K6 it works perfect. i still have to mill down my spacer bc its off by an 1/8"
    sorry dont mean to clutter the thread, just explaining what i used on my 94
    May 2010
    so cal.
    Quote Originally Posted by Kruznlow69 View Post
    For now I won't be running A/C but think I'm going to try to run the 5.3 compressor in stock location with a modified frame and a/c mount. The 98 pump will work I'm pretty sure and for the radiator I used a stock 2001 silverado one so I could use the 5.3 hoses and coolant bottle.
    Ya mine is a DD too. I'm hoping the stall won't be too big of a deal around town.
    I may go that route but I like the idea of being able to take my a/c belt off for dyno and drag runs.
    May 2010
    so cal.
    Okay guys so a little update. The truck is up and running. It has been tuned a little but it is not quite ready to be driven daily yet. Still needs some tweaks on timing and fuel curves. And I'm going to drop the idle a little after it is tuned a little more. Right now it is set at 950. I have a couple pics of the engine bay nearly done except for some more wiring clean up. I have this squeak that sounds like it is coming from the bellhousing like the torque converter bolts or something. I can't identify it so listen on the video and see what you guys think. Feel free to ask any questions.
    http://www.youtube.com/watch?v=zPUrBBgSmhY
