deceided to put a three wire sensor in the stock location. what are the pins for that sensor? Is A and B the same and C to the gauge? Just a guess?
1997 ECSB Chevy 1500 2WD, Lowered, tinted, 17" Impala wheels. True duals dumped w/ no cats. Ford 9" with LS1 F-body Brakes. Hipster (ATD) 4l60E. 3000 Stall.
My Garage -----> http://www.ls1truck.com/forums/my-ga...tml#post252565
This is the diagram for your truck. According to it, terminal A goes to your ipc, as far as the other two, it's been a while since I've had to work on one of those but I believe one is 12v and the other is 5v, but I could be wrong. I'll get some better diagrams off mitchell at work tomorrow. I only have access to this alldata crap at home. Hope this helps.
1993 GMC Yukon GT, 6.0 vortec, head work, no cats, cai, HpTuned by me, jasper lvl2 4l65e, nbs brake conversion
I am refering to the three wire sensor that was refered to in the parts list as a three wire temp sender for a replacement for the 2 wire one that just sends the signal to the computer. it is not the stock one, that is a simple one, one wire.
The three wire sensor, the middle wire goes to the gauge, green, I believe it was. It has been about 5 years since I dicked around with one of those, though.
thanks
A = black(gray 6.0)............coolant temp input to ecm, low reference
b = yellow...........coolant temp input to ecm, sensor signal
c = green............coolant temp input for cluster mounted temp gauge
1999 2Dr Tahoe 4x4 - 5.7L L31 Mercruiser intake w/42lb inj, 411 PCM, FLT Lvl4 4L60E, PI 2800, LTs, 3" x-piped exhaust, 9.5" 14bolt w/4.10s & Auburn, Hydroboost, e-fans
Coming Soon: LQ4+cam
