Results 1 to 10 of 12
Thread: 5.3 to 6.0 Swap
    Apr 2010
    5.3 to 6.0 Swap
    I just got my 6.0L engine to swap into my 04' that had a 5.3 engine. The engine I got has the 3 bolt throttle body, and has 9k miles on it. If I want to keep the 6.0L intake and throttle body, what do i need to do. I have been lookingat post and haven't found a good answer. everything looks the same right down to the fuel rails.
    Tyler, TX
    Install it, if it all looks the same, that means it will work the same and everything hooks up the same. Hurry up and stab that thing!
    www.tjc.edu
    Apr 2010
    Going to start tommorow. We have been trying to figure out wht cam we want to use.
    Apr 2010
    Ok the motor is in and starts right up. I'm trying to figure out why the motor is stumbling. It is comming up with a random/multiple misfire code. Any ideas.
    Nov 2009
    Fort Smith, Arkansas
    Could be a lot of things but is probably something simple. Check to make sure your plug wires are on all the way, check health of plugs. If it continues test your coils.
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    RevMax 2800rpm stall converter
    Schoenfeld LT Headers
    Nelson tuned
    My Truck Video - http://www.youtube.com/watch?v=Rw9y1...&feature=email
    Apr 2010
    That is what I am hoping for. The plugs and wires are all new. The one header is leaking where the downpipe attaches to, hopefully that is the major issue.
    Apr 2010
    No go, still won't idle. Runs great at 1000rpms and higher. I think the tune needs to be adjusted. I'm going to call Nelson tommorow.
    Ponca City
    5.3 tune limits the 6.0. tune will do wonders
    Slowest in Oklahoma...
    Oct 2008
    Shawnee, Ok
    Quote Originally Posted by ecld_07 View Post
    ya, after we swapped out my 4.8 for a 6.0 i got murdered by a v6 5speed single cab gmc, but after i got my nelson tune i smoked him, a programmed titan, and a programmed 05 5.3 single. there beast with just a tune
    02 chevy 1500 ecsb. 02 lq4 6.0, nelson tuned.(sold but still in the family)
    89 chevy 1500 rcsb -under construction-
    Nov 2009
    OH! Well ya if you still have the 5.3 tune then of course its not gonna run right.
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    Nelson tuned
