Results 1 to 10 of 23
Thread: F150 LSx conversion - don't hate!
    Hey guys, gotta a truck here we've been working on.
    I know it doesn't fall into the GM category, but it does have an LS engine.
    Specifically, a 2002 5.3L engine.
    We're backing it up with a semi-built 60e.
    Rearend will remain stock.
    AC will work, along will all the gauges. However, gauges will consist of an Autometer set.
    Oh ya, something to really put it over the top! We're building a front mount turbo with a heat exchanger and a/w intercooler.
    The engine will be seeing about 5psi for now. Iron block 5.7L build is being thrown around as well, later though.
    Turbo is the standard T76 MP we use.
    Here is the rest of the build:
    http://www.ls1truck.com/newstorage/pics/codytat/
    Enjoy the pics:
    Feb 2010
    Odessa, texas
    oh man....u dont know how happy i am that its a fullsize ford
    good work guys
    1983 Ford Ranger- 2.3 to 205k mile 6.0 swap
    Dec 2004
    San Antonio, TX Area
    So far so good. Should look nice when completed.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Quote Originally Posted by danger_ranger83 View Post
    good work guys
    I knew you would like this build lol.
    btw, the engine fit just fine, a little work with the mounts, but not much, used the dirty dingo mounts again.
    notch the frame to accept the stock a/c compressor.
    Quote Originally Posted by Chevy-Art View Post
    thanks, it'll be at the track someday.
    Feb 2010
    Odessa, texas
    is that rubber line ran for the fuel lines?
    Russell racing approved rubber push on line, to a barbed fitting, the other side is 3/8 and 5/16 GM connection.
    Russell Performance 634140 - Russell Twist-Lok Hose - Overview - SummitRacing.com
    Russell Performance 640850 - Russell Fuel Rail Fitting Adapters - Overview - SummitRacing.com
    Russell Performance 640860 - Russell Fuel Rail Fitting Adapters - Overview - SummitRacing.com
    Makes it real easy and only one fitting needed. Plus, this hose, once pushed on, will never leak or pull off, no clamps required.
    Oct 2007
    looks good. There is tons of space under there.
    9 sec truck club
    Feb 2010
    washington
    What the hell is going on allen!!!! Built ford tough with chevy stuff!!!!!!!!!!!!!
    Ford makes it but Chevy shakes it
    hot & windy
    i seen a turbo LS1 mustang somewhere...
    00 FRC - just top end, exhaust, and a hot-air intake
    99 Sierra - 5.3 / 5spd
    ↓ click the pic for the build ↓
