Results 1 to 10 of 14
Thread: Is it gonna be enough?
    I have a 12" Alpine Type X sub, Alpine MRD 1005 mono block amp, and a Tsunami 5 fared capacitor. I have had this setup for a while and plan on getting a big ported box built and putting in the back seat of my CC. I just don't know if it will get as loud as I want in that truck?
    Maui, HI
    If your amp does push a RMS of 1000wts to each voice coil then I wouldnt change your amp. Just make a box ported to 32hz, install a line driver/Epicenter, and call it a day.
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
    The amp does a 1000 RMS @ 2ohm and 750 @ 4ohm.
    should be loud enough but i would go with a sealed box because ported boxes only sound good with certain types of music but you definatly want to push that sub with the rms or maybe more with that max of 3000
    Maui, HI
    A un tuned system doesnt sound good to certain types of music. A strong line driver and a good EQ will make a ported setup shine harder than a sealed (and sound better)...
    Feb 2010
    Central Texas
    I vote sealed but I'm no radio junkie, thats just how mine setup and sounds good with everything I listen too, mostly country.
    BB
    Quote Originally Posted by americanracing20 View Post
    False. Ported boxes sound good with all types of music if properly tuned. Never talk in terms of max wattage when dealing with car audio either.
    Quote Originally Posted by Rebel3190 View Post
    #1) Caps are bandaids for big electrical problems. Ditch it.
    #2) The Alpine X isn't meant to be super loud. It is intended as more of a SQ sub.
    #3) A properly built box can get anything to sound good.
    #4) I ONLY RUN PORTED BOXES.
    I dont agree with #1. I have a cap in mine , with an upgraded alt, the big 3 wire upgrade, etc and I dont see my lights dim anymore when the bass hits.. but everyone has thier own opinions based on their own experiences and knowledge.. so i leave that to you to decide.
    dunno about 2
    #2.. YES I AGREE.. my box is ported with a 3.5 inch SQUARE port on the passenger side.. my built it when a "big wig" designer with MTX was in his shop and I can that MTX gives its blessing to this design
    #4.. me to LOL
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    Quote Originally Posted by MidwestSS View Post
    dunno about 2
    #4.. me to LOL
    Now now... I don't tell you how to run your IT service Mikey. Leave the COD and car stereos to me
    just pulling your leg.... the third one.
    But on a serious note, here's a little heads up on caps.
    Car Audio Power Capacitors
    And I quote, "The first way most people know if their system is in trouble is headlights dimming. To most car audio enthusiasts with a passing knowledge of electrical systems this means a capacitor is needed. Headlights dimming? Get a cap. And that's a pretty good guess but not always true and certainly not a guaranteed cure. A power capacitor can only do so much. If your electrical system only has a scrape it's a good band-aid but if it's really bleeding you need stitches. And stitches come in the form of an upgraded alternator and battery. If the headlight dimming only occurs at idle then it probably isn't much to worry about and a power capacitor may help. An idling vehicle puts out much less current from the alternator while the current draw from the audio system remains the same."
    Mar 2010
    San Antonio, Tx
    +1 A ported box has much quicker response and usually the lower the tuning frequency the higher the SQ. I like mine around 28-32 HZ. Do set your subsonic filter (if that amp has one) to slightly lower than your tuning frequency so the subs wont suffer. And if you have access to an oscilliscope use that to set your gain for minimum clipping using a tone cd. Clipping is alot more audible in a ported box i think
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
