Thread: oil pressure problem
    Mar 2010
    houston,texas
    ths weekend when i was driving and i happened to look down at my guages and noticed that my oil guage was at 80 im not sure if something is wrong with my guage or my engine and when im idling its in the middle of 40 and 80 normal its right below 40 at idle
    2006 silverado crew cab z71 6.0
    Nelson Tuned
    LT
    285/75/17 bfg mud terrain km/2
    TSP 220
    when you noticed it at 80 where were you at in the rpm range, or were you at WOT? idling should be around 40 tad over or below, seems like youre fine
    Mar 2010
    Paris
    mine idles just a hair over 40, and anything over about 2800 rpm mine is at 80
    Truck: 05 GMC CCSB SLT Z71,
    Go Faster: 5.3, 219/227 .607/.614 112, milled heads, eBay CAI, Circle D 2800, 3030 Built 60E, E-Fans, 3030 Tuned, LT's, Spintech Muffler, DuraGrip w/ 3.73's
    Look Better: 10K HID's lows & fogs, tinted Chevy tails
    Mar 2010
    Paris, TX
    What weight oil are you running in your engine and what were the ambient temperatures?
    How long since last oil change?
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    Mar 2010
    houston,texas
    im due for an oil change and at idle it goes to between 40 and 80 it use to idle at 40 or alittle over i run 10w 30 so im not sure is the sensor is messed up or what
    Nelson Tuned
    LT
    TSP 220
    Mar 2010
    Paris, TX
    I have seen some odd issues with oil pressure and miss fires before from not changing the oil. I would recommend to go ahead and change it and see if it help before you start replacing parts. Always cheaper to perform maintenance first that needs to be done anyways. I would recommend 5W-30 in a good brand of oil.
