Results 1 to 4 of 4
Thread: advancing timing chain sprocket work anything?
    wtby ct
    im building a 6.0 with a z06 cam and ported factory heads with the decks cut about 25 thousandths.i have 1.75 roller rockers,long tubes a ported throttle body and going to get a cutom tune.im wondering if theres more horse to be found by me advancing my timing gear. a local builder is telling me its work it by going 2 degrees but im not sure and dont want to damage anything.my came has a 112 lobe seperation also if that changes anything.thanks for any help........happy easter everyone!!
    2001 Suburban 1500 5.3 4x4 Lt
    WHATS DONE SO FAR- CAI, 3inch Cat back with flowmaster,2-3 inch drop,rebuilt trans with hd2 transgo,TB Converter,aftermarket trans cooler,Tinted tail lamps,Street
    Scene grille,hids,punched Cats,20 inch incubus wheels,07 front brake upgrade,clear corners
    WHATS IN THE WORKS- 2005 6.0L swap in the works,long tubes,Z06 cam,ls6 yellow springs,e fans,ported throttle body all to come shortly
    Mar 2010
    Paris, TX
    Advancing or Retarding the cam gear will move the peak torque and peak horse power down or up (respectively). Retarding means less torque down low and more power up top witch would not be advised for a heavy suburban that needs a lot of torque to get rolling. Advancing makes the peaks happen sooner in the rpm range and more torque down low where it is needed for a heavy vehicle.
    As for as damage to the motor you will need to check your piston to valve clearance. This should always be done in my opinion. I recommend checking it with a checking spring and dial indicator (best in my opinion) or use the modeling clay method.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    I would have sworn its the other way around, advance for more torque and retard for better high RPM power
    Mar 2010
    Paris, TX
    You are right RedHeartbeat. I must need to go to bed to get some sleep. Changed it.
