Results 1 to 5 of 5
Thread: fuel gauge problems..
    Jul 2009
    Mid-Michigan
    My fuel gauge quit working recently,so i replaced the sending unit and everything,and it still dont work! Anyone have any ideas what it could be? The truck is a 02 Z71.
    May be the ICP. If you have someone with a tech2, have them sweep the gauge and see if it works.
    Jul 2009
    Mid-Michigan
    When i first turn the key foward,the fuel gauge moves, but then it goes right back to empty after a second.
    Cromwell, CT
    Do you have a friend with a similar truck? You could try swapping clusters. it could be the stepper motor in there.
    There is a guy here in CT that rebulds clusters.
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Jul 2009
    Mid-Michigan
    Well this morning i decided to try another pcm i had laying around for my truck,and the gauge worked great! So i switched my "race" pcm back in,and it dident work. I called my dyno guy and hes gonna look at it this weekend. And i forgot to add that the fuel gauge quit working when it was on the dyno.
    02 Z71-5.3/4l80e-P.I.2800-TR220-Ported heads-Pacesetter LT-Auburn E-locker-E Fans-42lb. injectors-RWHP 301-RWT 305
