Results 1 to 7 of 7
Thread: Will 15's fit?
    Plainfield, IL
    Will 15's fit?
    I have an 01 ext cab with front/rear disc (single piston in back if it matters)
    I had 16's stock, and was always told that 15's would not fit.
    I had a mudding mishap this weekend, and blew out my spare. Don't really feel like dishing out 400 bucks for a new one right now (and the tires I have are on backorder until july) Buddy has a couple tires that are close to the same size, but for a 15" rim. Will they clear the calipers?
    Buffalo or Rochester, New York
    15" rims will not fit on the front of our trucks the calipers hit. I tried to switch the stock tires / rims between my '84 K5 and '04 K1500 a while back and no worky worky.
    Kyle - 2004 K1500 Z71 RCSB 5.3
    - Nelson 93 Octane Tune - LPP Long Tubes + Y - Gibson Extreme Duals - Cut Up Stock Air Box - 10.95 @ 67 in the 1/8 -
    - '05 Pickup Front Brakes - '05 Suburban Rear Brakes - Russel Stainless Braided Hoses -
    - DTRL's Turned to Park Lights - 4-HI Mod - '05 SS Seats -
    - I downshift near hybrids so they can hear me hurting the environment. -
    Jan 2010
    spanaway wa
    also tried to fit 15s, and ended up selling them, because they didnt fit.
    Plainfield, IL
    knew they wouldnt fit 03+ because of the bigger caliper with rear drums
    thanks 99
    Oct 2005
    drinking your alcohol
    you can grind down the caliper... ppl do it all the time to run 15'' wheels for slicks and what not
    DamnYankee: my nana failed
    Jan 2010
    spanaway wa
    how much grinding would i have to do in order to get them to fit.
    Feb 2010
    15" is going to be a tight fit on these nbs
