Results 1 to 10 of 20
Thread: 4.8 NA build
    Hope Mills, NC
    4.8 NA build
    alright many things have changed in my life in the past year since being on the site. rather not get into that as its not important.
    now to the build:
    2005 gmc rst 4.8 5 speed
    just finished my t56 install with stock ls1 clutch and flywheel. looking to get an ls7 clutchsoon also, i just installed my new cam yesterday and yes its huge for a 4.8 but thats the plan. 236 242 .580 .590 @ 050 on a 112 with patriot gold springs and comp pushrods. Getting a live tune tuesday. The cam is so large in fact that it wont even idle on its own. just lovely alright heres the plan some 4.88's a strong clutch with udp. also looking into heads and intake. Im looking for bang for the buck. Looking for direction on intake and head choices id like to stick with factory castings and have them ported fully and decked to bring compression up. What would be a good combo on the 4.8 with my setup to bump compression and have more flow. Id like to stick with all factory parts such as head casting and intake to make it look as stock as possible. ideas on which casting/intake and how much to take off so i can still drive this everyday and run on pump gas... i want the motor to look like a sleaper and put the 4.8 to its full potential N/A thanks guys i know you guys will say go 6.0 but i want to do something a little different
    2005 GMC RST *sold
    2006 Silverado SS with nawz
    Woot woot go 4.8!
    go for 243 heads down, mill them a little bit, wont need to do a lot since the 4.8 has flat tops already, gen 4 intake and spin it to the moon
    Hope Mills, NC
    how much would you say to take off of the 243's theres a local machine shop that does big name high end motors. i was thinking of getting some 243's ported and decked and 07+ intake port matched to it. how much would you say to take off by decking? im gonna run a stock headgasket. also should i have them machined for bigger valves? im looking for a magic combo to make it scream to the moon
    2005 GMC RST *sold
    Hope Mills, NC
    anyone care to answer the question above? guess no1 cares about the 4.8 until i post track times!
    2005 GMC RST *sold
    Cromwell, CT
    have the machine shop cc the heads and the piston in the bore then they can mill the heads and get a head gasket with the appropriate compressed volume to get the compression where you want it.
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Hope Mills, NC
    taking the motor out of the truck isnt really an option. but i do understand exactly what your saying.
    since they are flat tops, does anyone know the actual compression with a stock headgasket/243 head combo. and also by milling off every.005 how much it would increase the compression? im gonna start googling this to see what i come up with
    2005 GMC RST *sold
    Cromwell, CT
    Quote Originally Posted by SNEEKY View Post
    You don't need to take the engine out to cc the piston volume. It can be done in the car.
    Things like head volume are not exact. These are just cast aluminum heads you are working with. I have seen CNC'd chambers that cc to a spec other than advertised. This is why I say to have the machine shop check this and mill accordingly.
    Keep in mind you can't add 2 points of compression by cutting the heads. you can only mill the heads so far before bolt holes and intake ports won't line up anymore.
    01 ecsb 5.3 4x4 z71
    61 Corvette
    Hope Mills, NC
    hmm well the motor didnt want to cooperate with the tuner i guess...unless someone wants to live tune it for me think im gonna do some gears and an ls7 clutch before i do heads and intake. but they are in my future sometime this summer.
    2005 GMC RST *sold
    Lakewood,Co
    in not sure if a 4.8 has gone 12's n/a, go for it. a 6.0 can hit that cam only, it all depends on the money you have to spend. i started out with a 4.8 im now a 6.0 with a t76 fm turbo will see how it goes
    Silverado:6.0 LQ4**4l80e T76 FM Turbo*** -efans EFIlive tuned-TrueTrac
    Camaro: MTI x1 cam, MTI Lid, Free flowing exhaust
