Results 1 to 10 of 10
Thread: Transmission cooler lines *need quick advise*
    Union, MO
    I found a leak in one of the transmission cooler lines and it looks like it's coming from the hose section. I'm going to replace them both and wanted to know if this was going to be difficult or easy and if there is anything I need to do to the fittings to prevent leaks. Quick replies would be greatly appreciated since I'm gonna try and do them tomorrow night. Thanks!
    you dont have to replace the whole line, why not just replace the section???? but it shouldnt be too bad.
    Union, MO
    Well, it looks like is coming from where the hard line attaches to the hose section @ the crimped section. figure I'll just replace the whole thing. Parts are fairly inexpensive.
    OH ok now i see
    Tyler, TX
    what about buying an AN line? and just replacing hte whole thing while your at it with something that will last a while? i know factory lines usually last forever, but they can easily get cut or pinched
    www.tjc.edu
    Union, MO
    AN line?
    Union, MO
    Are there any tricks I need to know about these lines? I've read stuff about clips. Aren't both fitting screw type?
    Union, MO
    What size hard line are those tranny cooler lines? 5/16"?
    3/8"
    Union, MO
    Thnx
