Results 1 to 10 of 10
Thread: 4/6 drop in the works
    Feb 2009
    Tulsa, OK
    I was wondering if you guys that put a flip kit in used a plas to cut the frame? I dont have a recip. saw or portaband (two options I was thinkins of using) Did you plas it or should I stay away from the heat ya know?
    thx
    If you have access to a plasma torch, use it. It does not concentrate heat in a large area so you'll be fine.
    Jul 2009
    South Carolina
    i used a sawzaw with a metal blade it cut ours prefect drilled the corners so that i could make a tight turn. it not as easy but thats all we had lol.
    Grinder and a cut off wheel will work too
    Tyler, TX
    or a high powered laser, but seriously, plasma cutter is great
    www.tjc.edu
    Feb 2009
    Tulsa, OK
    My laser cutter is still on layaway but I do have a plasma cutter but was concerned about the heat. I agree I dont think it will be in one place long enough to matter. I heard it was a nono so I thought i would ask... How bout welding in the c notch? I heard that was a no no also? Any thoughts?
    wichita falls, tx
    From what I understand you do NOT want to use a plasma
    I used a grinder with a cut off wheel quick and clean
    Mar 2008
    Burleson, Texas
    Quote Originally Posted by Cowboy View Post
    Mine is welded in and it is fine. The only problem with it is that the guy who had it welded the vertical part of the frame but not the top or bottom section. The welding itself didn't cause any problem.
    '00 Silverado 4.8L (Gone)
    '11 Silverado 4.8L
    Quote Originally Posted by RUFFNECK View Post
    ...First relieve the pressure before doin' that or else you will get a nasty squirt and may get in ur eye.
    Feb 2009
    from my experience, use a grinder with a cutoff wheel, i use dewalt wheels myself, very quick and straight cuts, or a "Sawsall" with metal cutting blade, always dewalt, if you buy the cheaper blades they wont last. also on the welding note, welding in the notch isnt a bad idea, just dont let it heat up too much and warp, welded cnotches on plenty of trucks and never had any issues, including my daily, a slammed hardbody. when i do my notch im going to weld it in
    02 5.3 sierra rcsb,its stock i swear ....
    S.A. Texas
    Plas is the way to go if you have access to one
