Results 1 to 10 of 16
Thread: Poor Gas Mileage after swap?
    Wyoming
    I have about 500 miles on a newly rebuild Chevy 5.3 engine. I have all emissions removed and using an o2 about 10 or so inches past each header. No cats and an open filter. Other items. 1997 Dodge NV4500 5 speed, axles are 4:10 gears with 35" tires. My questions is, I am only getting 8 mpg and would like some guidance on how it could be improved.
    1969 Toyota Fj40, 2001 Chevy 5.3 Drive by Wire, NV4500. Build site at http://toysandbox.com
    Augusta, Ks
    Thats terrible mileage. I get 20 to 22 in my truck. Who did your tune?
    2004 Buell XB12s
    Nov 2009
    Fort Smith, Arkansas
    Quote Originally Posted by WARLOCK View Post
    In town?! Dam! How do i get mine to get that?!
    Sounds like you're not going into closed loop or your 02 sensors are bad.
    Wyoming
    I used Brendan at Lt1swap.com. Is there a way to determine how or if they are going into closed loop? It looks my my ODBII program will show open/closed loop. I use Diagnose ODBII on the laptop to monitor.
    scanning software like HPTUNERS or EFI-LIVE
    Wyoming
    Please take a look at my images. I was positive on your Closed loop. However, after running it in the garage for several minutes it went to closed loop. I really do not know how to read the O2 diagram. Does this look right? My Bank 2 looks odd. What do you think?
    And the other screen shot.
    Thanks for your help!
    you need a tune in the worst way. You're pulling 15.1 on fuel and its needing to probably pull even more. It should be about 5 max. RH 02 sensor is bad, too. Replace it first before attempting a tune.
    Wyoming
    I will look into something like HP tuner or ? Would this effect my flashing or cause it to be reflashed? While I did the full rebuild of my LC, I know very little about the engines. Thanks so much for the info on the tuning. I will research them a little and may have quetions.
    For the other - Here is the link to the software I bought. It is read only to your ECM.
    OBDII Diagnostic ScanTools and code-readers
    Jun 2009
    Cocoa, FL
    What software is that?
