Results 1 to 10 of 15
Thread: a little gear noise any remedies?
    Mar 2008
    hampton bays NEW YORK
    i replaced my front and rear gear to a set of liberty 4.10 gears and replaced all of the bearings, racers and seals. i have a little noise or wine . i set the lash with the proper tools and right grease smear pattern. i heard that aftermarket gears can be a little noisey but is there any fluids or different gear oil people have used to help keep their gears cooler and less noisey???
    Still running stock carriers?
    well to tell you the truth most after market gears a going to whine. i just recently changed my gears too. i went with oem 410s and i am glad i spent the extra cash for them no whine or noise at all.
    dont think you can change oil to make them whine less it just how there going to sound.
    oh and i know my truck is new but i did not replace any bearings and i used lucas gear oil.
    take the covers off and check your pattern again. Sounds like you got it wrong or just bought some single cut cheap quality gears.
    Jul 2009
    +1 on either cheap gears or something is a little off or tight
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Augusta, Ks
    I agree with the cheap gears. Never heard of liberty.
    2004 Buell XB12s
    Quote Originally Posted by WARLOCK View Post
    I agree with the cheap gears. Never heard of libery.
    Me EITHER.
    Wasilla, AK
    Is the noise on accel, decel, or cruise?
    Mar 2008
    gear speed
    when i let off the gas and coast. i was thinking better fluid and a trick flow finned aluminum cover to help bring the temp down and the niose hopefully
