Results 1 to 10 of 16
Thread: Limited-Slip Options
    Saint Marys, GA
    I'm looking to upgrade my factory G80. I had in mind an Eaton True Trac but Thunder Racing recommended a Moser differential because it either doesn't require the special bearings or comes with them (can't remember??). The local shop around here suggested an Auburn Carrier and they have one in stock for $390. I'm just looking to get some input on what would be my best bet to withstand a high horsepower application.
    Thanks
    Trevor
    Current Mods: 6.0/4L80e with Trick Performance Front Mount
    Audio: Pioneer avic-d3, Memphis Belle, Two 12" Rockford Fosgate P3 shallow mounts, Memphis MS-Qs, and custom vinyl enclousure.
    Crossett,Ar
    Tru Trac has show to be the strongest on this site and probably will come out to be advised more. I run a Eaton posi and it is pretty well equal to the auburn from ratings I've see. Both are pretty good.
    +1 on the Detroit TrueTrac. Get one from Ron's. You should also get a Master Install Kit for the GM 8.6 10 Bolt.
    Nov 2006
    Mesquite, TX
    i like the true trac...i have had both Auburn and True Trac and i replaced the Auburn after a month cause i blew it up just like the g80...pissed me off cause it took everything out...Havent had any problems with the True Trac at all
    2006 silverado SS....Clifford Jr...turbo coming soon
    1970 Chevelle ly6 swap....d1 coming soon
    Saint Marys, GA
    Thanks guys, I'll stick with the True Trac! And Ron's has some pretty good prices too!
    ...which is why all of us buy them from him!
    Augusta, Ks
    I will be going with Ron as well. When the time comes.
    2004 Buell XB12s
    Okeechobee, Fl
    Quote Originally Posted by txarkitekt View Post
    +1 thats where I got mine about a yr ago.
    49 Ford F1
    Jul 2009
    Truetrac all the way... no clutches!
    ... and who is Ron?
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Jul 2009
    Nevermind. Checked his page out. Great prices.
    06 2wd
