Results 1 to 10 of 30
Thread: 5.3 in my 78 C-10
    Aug 2009
    5.3 in my 78 C-10
    here are a few pic of where im at on my 5.3 conversion !!!
    Looks like its coming along just fine.
    Gramercy
    looks real good man!
    what's the specs on the engine/tranny? mileage of the truck? what did it come with origanally?
    whats the future plans of the build?
    2008 GMC CCSB 6.2/6L80e swap
    Gen IV 5.3/60e swap 1994 ecsb W/T
    Aug 2009
    its a 2000 5.3 with a 4l60e the truck was a factory diesel first year (78) 5.7 its been off the road since it was repainted in 1993 so it a clean old truck the engine is stock for now gonna get it going back on the road then go from there
    Aug 2009
    ok so i install the factory fuel lines both the hi pressure and return all the wayto the filter i got the lines from the fuel rail to the tank my question is what will i do with the third line EV something has a green cap on it it goes grom the fuel raill area to the tank do i need this????
    If the fuel rail you have with your engine came with two feed lines it has a built in regulator. The 3/8" is the feed line from the pump and the 5/16" line is the return to the tank. If your fuel rail only has one fuel fitting you will need an external regulator or you can use the Corvette filter that has a regulator built into it. Wix 33737 is the PN for the Corvette filter.
    The EVAP can be removed and bypassed on vehicles that are not smog checked in strict states like Cali. If it's in a vehicle that was not originally equipped with an EVAP cannister then its not normally necessary in a transplanted engine setup.
    Aug 2009
    on mine has the 2 lines with the reg on the rail i use 2001 truck fuel lines they fit really nice so im gonna use factory filter the only line i need to make is the one from the back of the filter to the sending unit i was going to cut off the factory end where it hook up to the plastic line on the 2001 truck and just use F.I hose clamp to clamp it to the 87 sending unit but im worried the pressure will blow off the line i spose i could use compression fitting on that end though!!
    any thoughts???
    Aug 2009
    what kind of headers are those
    Aug 2009
    Quote Originally Posted by yaya View Post
    there from summit they are made by pacesetter there for 99-04 trucks they are on there website
    michigan
    and they fit without any issues???
    1986 rclb undergoing a 5.3 transplant
