Results 1 to 8 of 8
Thread: Nitrous Master Jet List
    Nov 2006
    Mesquite, TX
    here is a good reference for nitrous jets, covers most kits out there...Nitrous Outlet uses NX pills so refer to the NX chart for pills on there kits
    NX Ls1 jetting list from NX website RWHP RATED....GM Stg.1 EFI system, part number 20920
    Single jet
    50HP 35N 18F
    75HP 41N 22F
    100HP 52N 28F
    125HP 57N 33F (fuel side may be a bit rich)
    150HP 62N 33F
    NOS jetting 5177 kit DRY FLYWHEEL RATED 900-1000psi rated
    Dual jets
    75HP 28N
    85HP 30N
    100HP 32N
    NOS jetting 5168 kit wet for LS1 RWHP RATED 900-1000psi rated
    single jet plate system
    75HP 41N 28F
    100HP 51N 31F
    125HP 55N 35F
    150HP 63N 38F
    TNT wet kit for power ring RWHP RATED 900psi bottle 60psi fuel -6an feed
    dual jets
    100HP 35N 22F
    150HP 42N 25F
    200HP 51N 28F
    250HP 55N 31F
    300HP 63N 35F
    350HP 67N 39F
    This is another NOS chart from the COLONEL
    HP-- Single N2O--Dual N2O--Single Fuel
    25 .024
    30 .026
    35 .028 .020
    50 .037 .024 .020
    75 .042 .028 .022
    100 .047 .032 .025
    125 .055 .038 .029
    150 .063 .044 .034
    175 .070 .052 .038
    200 .082 .047 .044
    250 .093 .055 .050
    DynoTune Dry Kit HP numbers based on 950 PSI
    Single Dry Jetting DynoTune Kit
    50 BHP=.032
    75 BHP=.042
    100 BHP=.048
    Dual Dry Shot Jetting
    50 RWHP=.026
    75 RWHP=.032
    100 RWHP=.036
    here is a rough quick conversion for single to dual and dual to single jets
    " here's the math for turning single size jets into dual jets (it's not half size) single jet x .71 = dual jet size.
    Example of your first single jet,
    .062 x .71 = dual .043's, which is 147.5crank hp, or 125.375rwhp, as per NOS's way.
    Also, the Colonels table is NOS fwhp at 950psi and the 100 crank is actually dual .033 and nos used to send a .032 and a .034, that's what I got on my first 5177 and the math backs it up.
    Here is the math for converting dual jets into single jets:
    (.71 x size of one jet) x 2 = single jet size"
    schweet
    Feb 2008
    Shreveport, La
    so what the crap am I spraying with my 67 pill dry then?
    txstvanwilder: but i got lube so i didnt complain
    mean05: he told me a price and i bent over and lubed up
    truckinL33: 6'' is not enough, and 12'' is too much
    pcmcobra: don't drink and bid on egay...lol
    408.Luke: lol im not blowing im investing
    Nitrous Outlet LS1-LS2 90mm plate jetting...
    ------ n20 --- Fuel
    50 HP 35 ---- 22
    75 HP 41 ---- 28
    100HP 52 ---- 33
    150HP 62 ---- 38
    200HP 78 ---- 46
    Plainfield, IL
    NOS brand LS1 78mm plate jetting...
    ------ n20 --- Fuel
    75 HP 41 ---- 26
    100HP 51 ---- 31 (runs pretty rich)
    125HP 55 ---- 35 (runs pretty rich)
    150HP 63 ---- 38
    Ran the 55 Nos, with a 31 fuel, and it seems almost perfect. Reading around 12.5 on wideband, plugs look awesome. This is at 900psi on bottle.
    Have a stock longblock 2002 TA going with 66/32 next Friday. Has already run 7.04 on a fat tune with 66/44. Yes, looks like disaster but I wanna see 100 in the 8th from a stock LS1.
    Well I thought that i would post a little more jetting info on here for our single nozzle systems.
    HP N2O Fuel
    35 31 17
    50 35 19
    75 41 23
    100 52 28
    125 57 32
    150 62 36
    175 73 40
    200 78 41
    225 82 45
    250 88 46
    All of this jetting is on factory fuel pressure for LS based vehicles 55-58psi.
    Our single shark nozzle will flow up to 250hp and if needed we do offer a SHO version that will flow up to 400hp.
    If you are wanting to go above 150hp you will need to call us and order a custom SHO hose that will support the amount of N2O flow.
    Just so y'all know I have sprayed ALL of these settings on my personal truck and had great cylinder to cylinder distribution all the way to 250 HP.
    We do also have E85 jetting for most of our systems if you are running E85 just let me know and I will help you out.
    nitrousexpress.com
    facebook page
    youtube channel
    join newsletter
    Pm, Call (888)463-2781, or email Trey@nitrousexpress.com for Tech or sales
    MADE Proudly IN THE USA
    Here is the jetting chart for our 90mm and 102mm plate system at factory fuel pressure.
    HP N2O GAS
    50 35 20
    75 41 23
    100 52 27
    150 62 34
    200 73 39
    250 82 42
    300 99 47
    350 116 49
    400 136 52
    With 15300L N20 solenoid and D6 feedline
    nitrousexpress.com
    facebook page
    youtube channel
    join newsletter
