Thread: Clutch Assembly
    Castro Valley, CA
    Clutch Assembly
    Does anyone know if there is an aftermarket clutch available for 04 Silverado's? I just replaced mine in my Truck, which only has 33000 miles on it. . Granted i changed out the 5speed for a t56 6 speed, and LS7 clutch assembly when my truck had 25000 miles on it. That said, i'm sure my clutch assembly will break again, so do you know if there's a company that makes a more stout one.
    On my truck, the plastic piece that holds the master cylinder in the firewall broke. . I replaced it no problem, but would like a real fix instead of just stock which i'm sure will only last a little while. I'll post some pics later so you have a better idea of what i'm talking about if you don't already
    2004 4.8l 6 speed manual 2wd
    Looks: 22" foose rims with Fierce tires, SS front bumper, SS Front Grill, 2/3 lowering kit.
    Performance: Volant Intake, 3" exaust with Spintech muffler, Pacesetter LT's with Y pipe, TR cam 220/220 .551 112 lsa, T56 Tranny with the Keisler short Shift kit and LS7 Clutch, Quicktime Scatter Shield, ASP Underdrive pulley kit, Dyno tune by Rick at Synergy Motorsports
    Soon to Come:Eaton locker, Electric Fans..Does it ever End?
    slidelll
    i whent with a spec stage 4 on mine
    the only crapy part is is sucks if your in heavy traffic you can feather it a little but its mostly all or nothing
    this is spec web sight
    LMPerformance - Camaro Parts, Mustang Parts, Corvette Parts, GTO Parts, Charger Parts, Trans Am Parts and more.
    http://www.streetsourcemag.com/ViewOwnerProfile.aspx?ProfileID=39253[/url]
    http://s133.photobucket.com/albums/q...sizerst/truck/
    Castro Valley, CA
    How come you can feather it? is the leverage point different or something?
