Results 1 to 10 of 19
Thread: Causes of high idle and idle surge...?
    Mar 2006
    Mesquite
    I assumed it was vacuum related, but haven't found anything. It idles high and surges on occasion. Ideas?
    Feb 2009
    Houston
    MAF sensor
    LMAO!
    Racoon Twp., PA
    No SES?
    Vacum leak, intake gaskets, intake cracked, fuel?
    2013 CC 5.3
    81 C10 LS1 project
    Jun 2007
    Theyre known for intake warpage and gaskets ,I had one ,but i was throwing a code . check all connections.
    Mar 2006
    Mesquite
    Quote Originally Posted by tanz45 View Post
    No SES?
    0507 which I believe is a generic "high idle" or some such thing.
    Your pot stash catch on fire? That might be the cause of your "High Idle"
    what about 02s? Definitely have Virgil hook up to it and see what the sensors are putting to the PCM.
    Nov 2006
    Mesquite, TX
    true you may need to replace the intake gaskets buddy, really need Louis to check the tune out also
    Dirty IAC, dirty throttle body, vacuum leaks as mentioned.
    Squirel in the intake.
    Round Rock, TX
    the surge could be from the TPS sensor not reading properly...It could be bouncing from 0-5% and causing it to surge. You got anyone handy with HPtuners to plug it in and check it, or a scan tool..
