Results 1 to 10 of 12
Thread: replace factory subwoofer
    wtby ct
    so my 01 suburban has a factory 8 inch woofer sounds ok but im sure i could get it to sound a little better by replacing it with something aftermarket.have any of you swapped your woofers out?what sounds good??my door have all the speakers upgraded so the rest of the truck sounds great just want some more bass without the box if possible.
    2001 Suburban 1500 5.3 4x4 Lt
    WHATS DONE SO FAR- CAI, 3inch Cat back with flowmaster,2-3 inch drop,rebuilt trans with hd2 transgo,TB Converter,aftermarket trans cooler,Tinted tail lamps,Street
    Scene grille,hids,punched Cats,20 inch incubus wheels,07 front brake upgrade,clear corners
    WHATS IN THE WORKS- 2005 6.0L swap in the works,long tubes,Z06 cam,ls6 yellow springs,e fans,ported throttle body all to come shortly
    Wichita Falls, TX
    Gotta do a new box and amp along with a new sub if you want to do it right and sound good. Everytime a customer didn't listen to me and replaced just the sub it was never good enough sound for the money spent on the new sub. Most of them actually sounded worse because of the sub being under powered. I built a sealed 8 box for a table that fit behind the factory plastic. After a dynamat door kit to cover the inside of the plastic it didn't sound too bad. I only did it this way because the owner was very hard-headed about it going there. Trust me when I say that losing a little bit of cargo room is worth the sound you will get. I've done single ported 10's which usually take up about 1 cubic foot in SUVs, even suburbans, and have had impressed and happy customers. An option is to mount the amp under the second row seats and run speaker wire back to the sub(s) and have a terminal cup on your box so if you do need the room all you do is pull the sub and fuse to the amp and fill'er up.
    You aren't going to be happy unless you do a custom box for your sub. In short, lo-lyf is right. It's going to sound like crap.
    wtby ct
    ok well i have a box already got a huge bandpass q logic box with some jl audio 12's.i used to run a jbl 250 rms bridged amp to the box it was unreal blew the amp long ago but ive held onto the box kept switching thru my vehilces worked great in the old 94 suburban but when i got this one it was just nice having room for whatever.thanks guys probably saved me some doe on not buying the speaker!!so have you guys run across anyone on here workin on there suburban.or just tahoes and yukons?
    I'm old. I like the sound of the 7th speaker inside my console.
    I have a pretty high end system for sale in the classifieds, but I'd NEVER, EVER EVER EVER, run a prefab box, especially a bandpass.
    Cedar Park, TX
    for best sound an amp is a MUST. i HIGHLY reccomend crutchfield.com i bought my amp, subs, box, and front speakers from them. they throw in all the extra little things needed to do the install for free.
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    Wichita Falls, TX
    amen, brother.
    Quote Originally Posted by jetersaurous View Post
    make sure you get the right amp for your subs. I highly recommend a reputable shop over any sort of online or mail order stuff.
    Never buy from Crutchfield unless you want to spend 2X the money.
    SugarGrove WV/Eubank KY
    i have a bazooka tube. and i love it. adds just enough bas to have a good quality sound. ive owned one in my last 3 rides.
    also i have used crutchfield before. they are heaper then any of the local stereo places and best buy. circuit city.
    01CamaroZ28
    10.751 @ 124.26 mph with a 1.446 60ft
    ALL THRILLS NO FRILLS!!!!
    B&L Racing stg 1 heads 224/581 cam.
    06 silverado 6.0L VMAX LPP LT's, Volant CAI, Manaflow, NELSON TUNE.
