Results 1 to 10 of 17
Thread: Air Conditioning not getting power
    I just took my truck to an AC guy and its fully charged with no leaks. The only way we can get the compressor to kick on is to take the relay out and jump the terminals.
    We checked all the switches and they seem to be OK. I took the AC heater controls out to see if I could jump the dash switch but there is 6 pins on it.
    Can I run a wire straight to the relay with a switch for now until I get back from the power tour?
    Does any body know which wire on the relay to run a hot wire to?
    thanks, Kris
    1997 GMC LS6 with 305 Accessories.
    1997 GMC RCSB
    LS6/T56
    Also, I put a new relay in it and it didn't fix it
    1997 GMC RCSB
    LS6/T56
    You need Lance's help. PM user NITROUS and see if he can help.
    Air Conditioning not getting power - FSC Forum
    here is more info about it if it helps
    1997 GMC RCSB
    LS6/T56
    Baytown, Tx
    Check your binary switch. aka pressure switch
    6.0, Hooker LT's, 60lb EDGE Jammer's, Procharger @ 11psi & Wheatley Tuned. Performabuilt Level 3 4l80E 3400 Circle D billet convertor, Eaton w/ 3.73's pushing 285/50R20's. 12.9@104
    I have checked all three switches.
    thanks
    1997 GMC RCSB
    LS6/T56
    Not all three of them are "jumpable" as a test.
    Oct 2003
    Did you install a three wire F-Body sensor in the A/C high pressure line, to allow the computer to control & cycle the A/C system?
    No I'm trying to use the 305 harness to run it.
    Please explain in detail I have no idea what I'm doing.
    1997 GMC RCSB
    LS6/T56
    check the 10 amp fuse.. i did the same thing. i felt dumb. deeee you emmm beeee
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
