Results 1 to 10 of 41
Thread: Sound damping
    newburgh, NY
    Sound damping
    I am going to do some sound damping this summer and I have a few questions.
    One, how much mat am I going to need to do a extracab sq.ft wise to do floor,roof,door, and the back wall.
    Two, what about the spray stuff would it be worth it to spray the inside if the doors?
    Three, I was considering second skin but is there a better stuff?
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    Paris, Texas
    i used a 50sq ft. roll on a single cab, had multiple layers on a few spots and i still have a good bit left. i did the floor, back wall, roof, and both doors
    I'd get 100 or more. You would be much better off taking your door panels off and lining the inside of the doors with the same mat you use for the rest. Don't use the spray, and don't skimp on sound deadener. If you buy the cheap stuff,theres a really good chance your truck will smell like asphalt every time it hits 90 degrees inside.
    newburgh, NY
    The second skin stuff is butyl not asphalt so it shouldn't smell on hot days.
    Step 1. crus at it.
    Step 3. torch it.
    Paris, Texas
    i used fat mat on mine. i rode in a car that had just been sprayed with that lizard skin and it reeked the whole trip. it was like 50 degrees outside too.
    Dec 2004
    San Antonio, TX Area
    Quote Originally Posted by sierraman View Post
    I was thinking of using Lizard Skin, I was going to do the firewall and the bottom of the cab. Had it not finished curing yet, is that why it still smelled bad?
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Paris, Texas
    i'm not sure it had finished curing or not but i know it was sprayed the day before and sat overnight before they put the interior back in, we were out driving it less than 48 hours after it was sprayed
    Quote Originally Posted by Chevy-Art View Post
    Round Rock, Texas
    I've got a '04 ECSB and used about 80ft^2 of fatmat. Did two layers on roof and back wall, and a single layer on all doors. I can crank the bass and barely hear it outside, no rattles either. It goes for around $130-$140/100ft^2 on eBay.
    Paris, Texas
    did you like having blue hands afterwards too?
    Jun 2007
    y did ya have blue hands?dont say it had something to do with a smurf.
