Results 1 to 5 of 5
Thread: intake swap
    Feb 2008
    IOWA
    intake swap
    I have a stock intake and thought about the camaro intake swap. I had mixed reading about that. Who has done it and what are the pros and con's? I have two if anybody needs one
    03 Silverado Extended Cab with 06 front end, Cai, Road Ripper 2000 Trans
    Richardson
    I tryed it on mine about 6 months ago and it killed my bottom end, I think it was my gear at the time 342 and stock trans & convertor, may be lower compression w/ the 5.3 not sure, anyway i put my stock intake back on and it ran much better..
    2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
    Richardson
    I am now cutting the top off of a 5.3 intake to open up the upper flow chamber and i need to find out what it will run like..
    Feb 2008
    IOWA
    my power plant is all stk so i get it would do the same thing yours did! thnks
    San Marcos Texas
    IMO this is a waste of time and money. The truck intake works great.
