Results 1 to 10 of 14
Thread: trans gone
    trans gone
    well my 2nd gear is gone in my trans after a trip to the track last night... come to find out my belt is a little too big for the truck so it threw the belt off the supercharger but i did run a 14.7 and 100mph in a 1/4... ill post the slip in a few hours after i get it out of my truck... so my ? is about trans.. this guy at the shop has a lvl 3 flt 80e in his shop for a pretty good price would this hold up in my truck or should i just order a higher lvl 80e?
    2007 silverado new body 5.3 procharged 9lbs of boost. comp cam custom grind... 463 rwhp and 401 torque
    Augusta, Ks
    It will hold up IMO
    2004 Buell XB12s
    ff_jeff Guest
    Check to see compatability. I know yours is different than the older ones
    i called him today , come to find out hes already sold the trans... back to the drawing board.. what about if i just get aamco to build me a trans? think that would be ok? has anyone had any experience with aamco?
    IMO, go with a level 5 from anybody. my lvl3 did not hold up
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    ^^^ He said 80E (eighty ee)...
    update on my trans
    ok so i found a tranny shop here in orlando says he does some work for guys who race out at the track i go to... come to find out i have 4l65e trans.. hes going to rebuild it with all high performance parts hdtransgo stage 2 corvette servos the whole works with a converter 3000rpm stall for 2200$ out the door.. did i get a good deal or no?
    Spring, Texas
    I would save the money and do an 80e swap. The 65e will break eventually no matter how "built" it is.
    Apr 2005
    Quote Originally Posted by ramair2002 View Post
    Yup. Your weight is what is working against you. Too hard on the trans to get something that heavy to move quickly.
    Gone, but not forgotten!
    Spring, Texas
    I wanna say there is a sticky on doing the swap somewhere around here....
    http://www.ls1truck.com/forums/front...rans-swap.html
