Thread: v6---->ls1
    v6---->ls1
    i just bought an ls1 to swap into my 4.3 silverado. it is just a longblock(water pump, intake, fuel rails, injectors, internals). what would i need to get this up and running? also, would my 4l60e hook up to this and hold or will i need a new tranny? it did not have an oil pan either. would i be fine with a stock ls1 oil pan, or would i need something else to fit my truck?
    SA, Texas
    tranny will mount up!
    i think its this thread that will be of much help to you
    http://www.ls1truck.com/forums/lsx-t...onversion.html
    ill double check
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
    you will need a crank spacer, longer bolts and flat flywheel or a custom torque converter to mate the old style transmission to the 300mm type setup. The converter is the best way to do it. This will allow you to re-use your old 4.3L 60e.
    bookmarked... i don't know what i'd do without these forums! thanks
