Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 58
Thread: School me on "Flex Fuel"
    Anaheim Hills, CA
    Yes I am new here , but as some of you may know, I will be installing a 2008 5.3 into my '72 Blazer. I will be picking up the motor this weekend. I am not sure if it was a flex fuel motor or not (how do I tell?)(dont have the VIN untill this weekend). My questions is, will this have any affect on my conversion? Anything special might need to be done? Not sure yet wether or not any of this applies, but worse case scenario, what do I need if anything?
    ...........Workin' on it...........
    Dec 2008
    Here you go..
    Anaheim Hills, CA
    So, a 2008 5.3 did not have flex fuel injectors?
    Dec 2008
    I would think it was optioned for 08, and the injector plug should be the same.
    Never seen the middle style on a stock truck. 3800's have those though.
    Anaheim Hills, CA
    ........So what make a motor a flex fuel motor? Is the ECM and the harness the same as a non flex fuel? Anything else that may be different?
    Dec 2008
    san antonio TX
    hey sandking the 5.3L motor that im going to get is also a flex fuel motor, but its missing parts on the intake so if i swap out the intake, harness and the pcm from a 99 model will it work.
    Anaheim Hills, CA
    I guess my question is this, if the engine is a flex fuel, cant I treat it as a normal engine? I just want to gas it up and go. I would rather not swap anything, but if the install and tune will be a PITA, I will. I just dont know the difference between the two.
    There's no difference, just plug and go!
    The tune in the pcm can go either way, so just running gas is fine.
    Since you're probably not using the rest of the fuel lines, tank and sensor, don't even worry about if it's flex fuel or not, just treat it as a regular non flex engine.
    If it is, it came with larger than standard injectors, so that's good.
    Just make sure you have 58psi or so of fuel pressure.
    later,
    allen
    Oct 2008
    E85 injector size
    later,
    allen
    Do you know how much bigger the flex fuel injectors are? I am assuming 30% to match the btu difference between E85 & pure gasoline.
