Thread: Double Din
    Aug 2004
    Magnolia, TX
    Double Din
    just bought a double din for my truck. need some help finding the right dash kit for it. radio is a pioneer avic d2. truck is an 06 RCSB non bose. TIA
    wichita falls, tx
    dash kit is a metra 95-2003 and harness is a metra 70-2003 you will also need a antenna adpt it's a meta mdp-4 ok the harness you will have to run your own ign either got to the fuse box and tie into the wiper fuse or go to the column and tie into the pink wire not sure of the best or scoshe part numbers on the kit and harness hope this helps
    Oct 2008
    Houston
    FYI, I just put Nav in my Tahoe, GPS antenna works fine placed
    on dash frame behind radio and UNDER dash pad.
    Save much time, rather than mounting it outside somehow.
