Results 1 to 10 of 20
Thread: Long Tubes on a 4x4
    Georgetown, SC
    Long Tubes on a 4x4
    What long tubes you guys running on your trucks that are 4x4. I've heard that some of them have to be modified around the driveshaft etc. I'm looking at the Pacesetters and just wondering if they'd have to be bent any.
    John
    Four by Four to the floor.
    Racoon Twp., PA
    PS longutbes, had to slightly flaten drivers side of Y pipe. I have a 6'' lift though and the front drive shaft is dropped 5 ''. Other than that, no problems.
    2013 CC 5.3
    81 C10 LS1 project
    Jun 2005
    Way up in North Dakota
    Tri Y Thorley headers. [ I know not a true long header ]
    welded flanges on the cat bolted to collectors.
    Cut up the stock Y moved it back about 1 inch.
    Nov 2004
    Rouses Point NY
    Quote Originally Posted by metalchips View Post
    Where did you get your Tri Y's, I wanted to look into a set of these. I heard you can get a lot more bottom end out of these over true long tubes. I'd rather have a lot of bottom end since i tow all the time.
    05 Crew Cab....just starting the mods!
    5.3 w/ Airraid intake tube, stock box with K&N, MBRP 3.5" cat back, Dynatech Longtubes, wait4me tune....to come...4.10's, custom Dyno Tune, maybe a few other goodies.
    Jun 2005
    Got them from
    Summit Industries, Inc [not Summitracing]
    ph# 951-739-5900
    Part #
    THY-310Y-49-C
    year 99-01 no smog fittings
    May 2006
    Waco TX
    Im running Pacesetter Long Tubes on mine. Plenty of clearance. I did not get the y pipe I had mine custom fabricated.
    Nov 2004
    Rouses Point NY
    Got them from
    ph# 951-739-5900
    Part #
    THY-310Y-49-C
    will they fit an 05?
    Dad gum it....I've heard the PS LT's won't fit SSS, Denali, Escalade AWD.
    May 2006
    Waco TX
    I did not have a problem at all. It was a bitch to get the drivers side in, but i got it in.
