Thread: bcm swap
    Apr 2003
    TULSA
    I recently purchased from ebay a 00 BCM (Body Control Module) for my 99 sierra. I have been told that this swap will clear the airbag light on my escalade cluster and I will be able to turn the drl's/headlights off with the cargo light switch or dome override switch. Has anyone done this swap and do they have any probs when doing it? I have an HPP III also that is currently installed, but I think that it reprograms the PCM. I am going to return the PCM to stock setting just in case there is a problem. My plan is to uninstall the hppIII, disconnect the battery, swap out bcm's, reconnect battery, program the bcm to the truck's r-code, and then re-install the hppIII. Just curious if anyone has had any issues. Any install suggestions would be helpful.
    May 2003
    Tallahassee, FL
    not an answer, but i had no idea that the new trucks (99+) had a separate computer that covers components out side of engine operations, or has this type of equipment been part of most vehicles all along?
    1989 GMC 1500 f/s stepside reg. cab--4.10's w/Eaton posi--Swapped in LT1--T56 w/SPEC clutch--LT4 Hotcam Kit--Lt4 km--Vented opti conv.--Meziere h2o pump--Taylor over-the-valve-cover wires--K&N CAI--Dynomax coated mid- length headers--True dual Flowmaster 40's no cats--Pcmforless programming
    323rwhp/332rwt
    13.5 @ 98 1.9 60' (with old 700r4 and ET Streets)
    1998 Z28 A4--stock
    don't know if this helps, but when the fbody guys remove thier airbags and change the steering wheels, they put a resistor across the wires that go to the airbag,
    i'm sure this doesn't help, or maybe it does,
    good luck,
    allen
