So here the deal i have a 04 rcsb 4.8 with following mods
comp 212/218 w/supporting PRs and springs, JBA ti coated shorties, CAI, Loud exhuast, ASP Underdrive pully, LS1 fans w/harness, Built 60E, Eaton LSD, Tune by 12secSS, Baer Alumisport all 4 corners, Hotchkis swaybars front & rear, Nitrous Outlet truck plate, twin 15lb bottles, Trick Performance controller, 860 heaters and NX bottle openers
A few weeks ago a squeak started and i have had just about everything possible checked.
I first started in the engine bay with all belts and pullys and so forth when we noticed the sound wasnt even coming from the front but more from between the trans and oil pan.
So with that bit of info i took it down to my trans guy who aggreed that the noise seemed to be coming from the stall or possibly the trans pump so to make sure they disengaged the trans and stall from motor only to have the noise still be there.
Ive been told it may be crank bearing or cam bearing but i dont know since there no oil pressure problems any ideas suggestions please help its driving me insane.
Edit: and it only becomes audible after about 10-15 min of driving and only when at idle or slowing down if i give it gas the noise stops until i let of and the trucks hit about 30mph and also if i turn on the AC it seems to almost go away but slowly comes back. When the trucks cold no squeak i can even here the squeak turn off truck and back on and the noise will be gone but quickly returns.
