Results 1 to 9 of 9
Thread: Truck Vs. F-Body Oil Pan
    SOMO
    I am getting ready to do my 6.0/4L80 swap in my 1990 2WD truck, can i use the truck oil pan? and if so how far below my Xmember will it set? I am doing a 4/6 drop and i don't want it to be hitting anything that i come across in the road.
    I can't remember off hand but if nobody tells you before tonight I'll measure it for you.
    May 2004
    I'll try to get the truck also but here's some info to help.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    SOMO
    I know that the truck one is around 8 3/4 deep i think as where the f body is only 5 3/4 ish
    I just didn't know how low it would hang.
    San Marcos Texas
    I would use the f-body if it was mine. I know the last swap Allen did they were concerned that the truck pan would hit. That truck would lay frame.
    May 2004
    And here's a good link at LS1Tech with the truck dimensions.
    Dimensional differences between LSx oil pans? - LS1TECH
    BTW, I'd stick with the F-body also to be safe not to mention it's easier to drop the engine in place.
    97 GMC, 2002 LS6.
    I'm running truck pan 12560392 and it sits 1.25" lower than the front crossmember at the centerline of the truck. The Fbody pan/windage tray/pickup tube/dipstick assembly is the way to go on a slammed truck for sure, especially if you like to drive while dropped.
    SOMO
    Dang, thats not what i wanted to hear.
    How much did that setup for the f-body swap cost you if you don''t mind me asking?
    $125 for all the parts to convert to Fbody pan is what I paid. Its a little hard to find them used sometimes. Post up on LS1Tech.com in their wanted section for the parts listed.
