Results 1 to 10 of 17
Thread: New Lq9 Just Came In The Door!
    im stoked! brand new lq9 crate motor. pulling the heads for minor bowl work and install 26918 springs and retainers. installing comp cam 265hr 212/218 558/563 on 115. reusing my 80mm tb and long tubes. will get it to alan for retuning once complete. anything im forgetting before droping it in please ring out. would hate to get half way into the swap to realize i "should have" this or that. how bout injectors maybe? will the stock 05 5.3's work alright? should be a straight foward install from what ive read. same flywheel, starter accessories correct?
    Apr 2005
    where'd ya get it?
    Gone, but not forgotten!
    gm dealer. part 89018179. all new. even came with sensors, plugs, water pump, balancer etc. id hump it if i could.
    2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
    Quote Originally Posted by MEANGENE75 View Post
    jesus how much did that set you back?
    Oct 2007
    Bandera, TX
    ya it will all just bolt in..... You might want to go ahead and throw some forged pistons, and h beam rods.... and while your at it some Clevite hp bearings, and a Melling oil pump and comp double roller timing chain..... This is what I did.... I bought the exact same motor, then completly rebuilt it.... lol, if you need any new parts I know where some are.... you will love it.
    single digit street truck
    for build info
    ff_jeff Guest
    Why not go bigger on the cam?
    really need the drivability, thats why im keeping the cam a little on the small side. appreciate the input guys. the bottom end needs to stay stock for this particular project. i just cant make myself throw away good new parts. (besides the cam anyway). i take the advice on the injectors and leave em alone for now and let alan tell me if i need the upgrade or not. truck will probably never go to the track or see a dyno, i haul my kid to school every moring in this thing.
    Oh damn, it will be an easy swap then. Is your 2005 truck a FlexFuel model? If so, it has bigger injectors than stock 5.3L ones. I would leave the injectors on there and have Allen read the duty cycle and see where you are on your fuel trims... Are you using the stock stuff--like coil packs, truck intake manifold, etc?
    seems like you bought yourself a nice motor, the bottom is is plenty for what it seems you want out of it, the injectors should work, might think of some marine 8.1s though, besides that all should swap easily for ya.. cam is small, could go up to a 222 or 224 or even a 228 on the 115 lsa and still be an awesome daily driver for ya..
    Simple: 408 on steroids!
    single digits coming soon!
    Apr 2005
    I would guess it's a combo of the crew cab, 4.10s and stall. But you are right, that is closer to the mileage I get.
