Results 1 to 8 of 8
Thread: Shocks
    Mar 2006
    Mesquite
    Shocks
    I got mine done pretty quickly, but mainly asking this out of my own curiosity.
    When I was removing the top nut on the front shocks on the drivers side, it was apparently just spinning the piston. I wound up using one of my new ratchet wrenches (which rock - everyone should have a set) on the nut and Vise-Grips on the threaded post. It loosened up easily enough (fortunately) but just curious if this is typical or if there's another way to get it off without it just spinning...
    burlington,Co
    cut the nut off with a air hammer,and if that dont work just cut off the whole post.takes 30 seconds.
    2008 Trailblazer SS 2wd red jewel 1ss
    Forged 365,Tvs1900@11psi,IW 8 rib overdrive,duel pass heat ex,Prc heads,blower cam,Yank,Aeromotive,ect
    Saginaw, Texas
    most the time when they go bad moze they spin... i had to do what you did last time... if you have an impact you can hit it in short burst it will spin the nut off without spinning the piston. does not always work but that is what i do first to see if it works...
    I am gonna be a new Daddy...
    Drive it like you live hard and fast....
    '91 rcsb, 4.3 V6, 700R4 trans swap, 4/6 drop rolling on 18's, roll pan, 2" cowl hood, electric fan, TBI injector spacer, K&N filter replacement, flowmaster muffler...
    [Today 08:09 AM] ChevyLee: dale would make a awesome dad in law too
    Mar 2006
    Mesquite
    Yeah - no air hammer or air gun, so I had to do the Vise Grips method.
    May 2004
    I use a high speed butterfly impact and it's always been able to spin the nuts off with a little side to side pressure.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Jan 2007
    Burleson,TX
    i used the vise grip method...that way just in case i can always reuse the stock shock
    06 silverado CC Volant CAI/ Corsa Sport exhaust
    dynatech supermaxx headers/cats
    LPE GT2-3 cam/ Comp 918's/ Rods
    Eaton LSD 3.73's
    IAT Shocks
    DANNY TRANNY w/2800 TCS billet verter
    275HP and 293TQ Pre Cam
    314HP and 303TQ post cam
    Mar 2008
    Mt. Vernon
    I thought for some reason the top of the shock was made so you could put a wrench on the bolt and another on the rod. I want to say that's how my stock shocks were.
    Jan 2007
    Burleson,TX
    yuppers most of them have that
    Eaton LSD 3.73's
    IAT Shocks
