Results 1 to 8 of 8
Thread: Picked up My 5.3 Engine 2004 from SSR
    I scored a 5.3 out of a 2004 SSR with about 650 miles
    #862 HEADS
    ROCKER
    PUSH RODS
    VALVE COVERS
    TIMING CHAIN COVER
    ETC
    I am now going to need to get the rest to get it running
    Need to locate oil pan, and top end, ect
    72 Chevy Stepside
    Not sure, 5.3 or Lt1
    Dec 2003
    Good find! Are those blocks from the ssr aluminum??
    2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
    Yes they are. Here is the picture of the engine.
    72 Chevy Stepside
    Oct 2003
    Houston
    How did you come across such a deal. Was the SSR wrecked or something?
    99 Pewter SCSB
    DJM 4/6 drop, Hotchkis front/reat swaybars,Hypertech power programer, milled & built heads, Accel wires, distributer,coil, Mass Air Flow Sensor(mti motor sports, Granatelli),Dynomax UltraFlow Stainless, 17x8.5 Eagle Alloys, Escalade door handles, Suburban front grille, with clear corners and billet bowtie,Street Scene mirrors, Cowl Hood
    Jan 2004
    sounds like a good deal.
    Dec 2003
    i thought they had ls1 5.7 in them?
    old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
    New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
    future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
    Yes the SSR was wrecked. Also if you check chevy's website it is a 5.3L Aluminum Block.
    Soon the fun begins, I am going to put a t56 behind it.
    72 Chevy Stepside
    May 2003
    Wichita,KS aka DOODAH
    They are aluminum 5.3s.
    We have a customer that has one.
    We still have not talked him into bringing it in for a dyno. run
    1990 SWB 2000 5.3l 4l60e
    It's in just tieing up the loose ends.
