well im buying a 2000 chevy 2500 with a 350 and it has 226000 miles on it and is considering my options for a motor swap.
IS it that much easier to do a direct replacement or go with an ls motor or just get a built 454
04 Pontiac GTO
06 Pontiac GTO
03 GMC Sierra 2500
and a bunch of other vehicles
Its cheaper to buy one that already has the LSx type engine in it. Step up to a model that has the 5.3 or 6.0L. You'll save many headaches and a lot of money in the long run.![]()
well for 2500 bucks ill stick with the one im looking at
04 Pontiac GTO
06 Pontiac GTO
03 GMC Sierra 2500
Sounds like you got a great deal. For that money I'd drive the wheels off of it then throw it away when it blows up. If you insist on repowering the truck then do a 6L or step up to the plate and put in a 408 or bigger stroker engine in it for some serious pulling power plus decent mileage for a big inch engine. The 454 or an 8.1 will kill you on conversion costs plus fuel.
the easiest approach would be a direct replacement.
i got it today, i thought it was a 350 but it turned out to be a 454. runs damn good, just needs some fuses and relays
04 Pontiac GTO
06 Pontiac GTO
03 GMC Sierra 2500
Need to add some smaller chamber heads and an auxilliary fuel tank, too. 8 mpg would suck unless someone else is buying the fuel.
i get 6 if im lucky with my 03 2500 6.0, i pull 8 tons every day so im used to getting raped at the pump
04 Pontiac GTO
06 Pontiac GTO
03 GMC Sierra 2500
Ouch! That's like my fuel mileage at the dragstrip!![]()
it cost me 150-250 bucks to get to the job and put diesel in my bobcat every damn day
04 Pontiac GTO
06 Pontiac GTO
03 GMC Sierra 2500
