Results 1 to 10 of 20
Thread: Lifter Offset
    Feb 2008
    Ona, W.Va.
    Lifter Offset
    Does anyone know that dimension?
    Eric "The" Pyles
    14.06 @ 96mph / 9.02 @ 79mph
    302 RWHP/298 RWTQ
    Well, if the lifter bore is 0.843-0.844" in Diameter, (the lifter itself is 0.700" in diameter) then the measurement you are looking for (radius) is .4125"-.422" or 10.71mm-10.72mm.
    Feb 2008
    Ona, W.Va.
    So the edge of the lifter bore lines up with the centerline of the cam?
    Eric "The" Pyles
    302 RWHP/298 RWTQ
    That would be quite a loose fit, wouldn't it? .143-.144" slop. Are you saying the plunger inside the lifter is .700"?
    Feb 2008
    Ona, W.Va.
    I'm glad you said that... I knew there was no way that was right.
    Eric "The" Pyles
    302 RWHP/298 RWTQ
    Jun 2005
    Way up in North Dakota
    I don't get it, need help.
    Your drawing is goofy, the center line of the lifter bore should intersect with the pivot point or arc center of the cam shaft.
    The way it is drawn one bank would be advanced and the other retarded. Or is it I that is retarded?
    Are you asking about the rocker arm to lifter bore tilt that the push rod has?
    Mar 2008
    A lifter bore that is out of round and/or has clearances larger than the lifter indicates excessive wear.
    Offset lifters are used with head and/or rocker combinations that require the pushrods to be set away from the intake ports or for any other side-to-side clearance issues. The offset has nothing to do with the tie bar in between the lifters. The lifters have offset pushrod seats left or right for the intake and/or exhaust, or any combination needed to gain clearance. -Crane Cams
    2005 RCSB; 5.3L; JBA cat-back; SLP intake; more stuff in the works...
    Feb 2008
    Ona, W.Va.
    Quote Originally Posted by metalchips View Post
    I was under the impression that the lifters sat "ahead" of the cam center line, that way, the lobe pushed them in a more upward direction instead of relying on the wall of the bore to direct the lifter up. I could be wrong.
    I had always assumed everything was in line untill a buddy of mine said otherwise... since then, I haven't been able to check.
    Eric "The" Pyles
    302 RWHP/298 RWTQ
    I got my measurements from this website I have saved on My Favorites.... Motor Dimensions and Specs. As for that .143 variance, you have to divide that by two cause you are using .143 as what is left over from the bore diameter and lifter diameter. So you have .071" of clearance around the lifter, based on what the specs say. To me, seventy one thousandths of an inch is pretty damn small... I just replaced all the lifters in Alan's truck in Tuesday night and they fit in there decently, but the plastic lifter cups also hold the lifter in place so that it won't wiggle around. And from what I could see, the lifters centerline is aligned at whatever angle to the cams centerline. It looked to me that there was no offset.
    Damn good thing you're an architect and not a mechanical designer. The slip fit of the lifter bores is closer to .002".
