Thread: newbie to this forum but not MODS
    Hey, there guys I am looking forward to providing help on this forum and learning as more about the LS series motor. I am not new to modding cars and trucks, when I was 16 I installed a LT1 into a jaguar xj12. I did the usual mods you would do to a Z28: ported heads,cam(a 227/233 @.050 with .550/540 lift) ,headers,ported manifold,MSD optispark,MSD coil, taylor wires, CAI, dual 2 1/2 exhaust,hughes 4L60E with a 2800 stall, and set of 3.54 gears with posi.
    Then at the age of 18 I Decided a 1965 GTO was in oreder so I started to build that and Im still in the building process. Check that out at lateral-G.net.
    Its a 600 hp 462 pontiac powered, tube chassis,mini tubbed, tko-5 speed, 65 gto drop top.
    Theres alot more then I just mentioned that Ive done to it.
    My current daily driver is a 1999 GMC sierra 2500 with damn near every heavy duty option you can get. this would be a: 6.0,4l80e,14 bolt rear with hydroboost,powersteering cooler,trans cool,oil cooler, etc
    the truck has roughly 160,000 miles on it.
    The truck is in damn good shape and is a rust free california truck.
    not trying to brag, I just want to let you guys know Im will to try the serious mods and let you know how they go. I want learn as much as possible from you guys or teach if I can. I may be young at 20 but Ive got a knack for anything and everything cars. Ive made a carrer out of it so far and I am currently into restoration and modification of nostalgic american cars.
    Oct 2007
    Bandera, TX
    Welcome, plenty to learn here.
    single digit street truck
    for build info
    SA, Texas
    Hello and Welcome to the Site
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
    Badass man! Welcome to LS1truck! Yes, there is a lot to learn here and we hope you can teach us a lot as well! Good to have you here. Any thoughts on modding your DD? Those 6.0L motors love FI...
    I plan on replacing my muffler on the truck first thing with a magnaflow dual inlet dual outlet. The truck came with dual 2 1/2 or 3 up to the muffler then it goes into a 2 3/4 pipe over the axle and exits. My muffler is going out and why not let the motor breath.
    I just thought it was funny the truck cam with true dual exhaust up to the muffler. What was GM thinking?
    I am also thinking what do I have to lose if I throw a set of AFR 205cc heads on there and a cam in the 220@.050 duration range and a 2200 stall and some long tubes. I know the bottom end is old but I think it could handle it for awhile. I dont want to go to nuts thats what the GTO and jag are for.
    Thats the same kind of setup my brothers 98 3/4 ton has on the exhaust. Weird.
