Thread: Off-road Y-pipe 99-02 GM Trucks
    Brand New in the box.
    $189 new, $189 from us, Free Shipping
    JEG'S Y-Pipes provide maximum exhaust flow for off-road truck use. These fit directly from the manifold to the stock cat-back exhaust for all 2WD/4WD applications and wheel bases. Constructed from 2-1/4'' mandrel-bent aluminized tubing, the pipes include flanges, gaskets, oxygen sensor bungs and plugs, and exhaust clamps. A JEG'S cat-back exhaust system is recommended to receive the full benefit of the increased exhaust flow. Catalytic converter(s), sold separately, can be added for street-legal use, yet some modifications will be required.
    Application:
    1998-2002 Silverado/Sierra C/K15 and 1/2 ton 4.3L except CA
    1999-2002 Silverado/Sierra C/K15 & 1/2 ton 4.8L/5.3L exc. CA
    If you're wondering if this ory will fit, check your truck, the driver side will have a flat flange to the stock manifold, and the passenger side will have a donut.
    SA, Texas
    bump
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
    SA, Texas
    ttt
    Her name is A Meli-
    ill give you 110?
    Dropped Ext Cab 99 Sierra, AirRaid intake, PowerAid Throttle Body Spacer, 3 in exhaust to a Flowmaster, Exhaust out back side of bed of truck, Bright Red, Projector Headlights, Billet Steering Wheel, Touch Screen DVD/CD player, Soon To have, N2O, Headers, Cam, Stall, Nelson Tune, E fans, Shift Kit,
