Results 1 to 8 of 8
Thread: Custom front mount single turbo setup for sale
    May 2007
    Las Vegas, NV
    I’m seriously debating changing my turbo setup to twins so my front mount single setup is up for sale. I built the setup myself; all piping is .065” thick 304 stainless from Stainlessworks. The manifold flanges are from them as well and are 3/8” thick.
    Asking $2499 obo Shipped in the Continental US
    Open to reasonable offers :cheers:
    Garrett GT4294 turbo
    TurboByGarrett.com - Catalog
    1.15 A/R turbine housing, probably less than 20 street miles and 8 ¼ mile track passes at 5.5 psi (new to tuning, the Chevelle ran a 14.05 @ 105 mph leaving off idle with a dismal 2.488s 60’, internally stock LQ4, stock 4L80E, 1600rpm converter, 3.73 rear gear, 26” street tires)
    T4 flange turbine housing 4” V band turbine outlet
    5” compressor inlet and 3” V band compressor outlet
    Tial 44mm v-band flange waste gate 11 psi spring
    Manifold to turbo piping is 2.5”
    Manifold flanges are 3/8” thick stainless steel
    Downpipe is 3.5” and has two O2 sensor bungs
    K&N air filter
    Stainless 48” flex radiator hose
    Oil supply and drain lines stainless steel braided hose, aluminum AN fittings
    Support bracket for mounting turbo to alternator/power steering bracket
    ***Does not come with cold side piping, intercooler or bov***
    ***If I didn't list it above, it does not come with the package***
    I’m not sure how I would ship the downpipe as it is; I would probably have to cut it into two pieces, but should be easy to reassemble.
    I’m fairly certain that this will fit on a fullsize truck and took a couple of pics with a measuring tape for reference. If you need any additional measurements or pictures, just let me know.
    If you want to see what this size turbo is really capable of, do a search for CurtD on performancetrucks.net…he has one on his truck with a built 5.3L running 12.0 @ 120 mph, making 619 rwhp and 657 ftlb PerformanceTrucks.net Forums - Dynoed today
    More pics can be seen here:
    Picture548.jpg - Image - Photobucket - Video and Image Hosting
    Picture551.jpg - Image - Photobucket - Video and Image Hosting
    Picture555.jpg - Image - Photobucket - Video and Image Hosting
    Picture553.jpg - Image - Photobucket - Video and Image Hosting
    Picture556.jpg - Image - Photobucket - Video and Image Hosting
    Picture554.jpg - Image - Photobucket - Video and Image Hosting
    Picture545.jpg - Image - Photobucket - Video and Image Hosting
    wondertruck Guest
    cool setup, wish it would fit a truck... very nice work
    May 2007
    Las Vegas, NV
    It probably would, if anyone needs some measurements to find out I'd be happy to take some. My buddy has a 2000 Chevy truck that I can measure against to make sure. The one thing that might need some tweaking would be the downpipe where it goes between the frame and the firewall, but that should be pretty easy.
    wondertruck Guest
    do that man, I might be interested if there's clearance, the downpipe is no big deal I could fix that easy.
    May 2007
    Las Vegas, NV
    Took some measurements off my buddy's truck (2000 Chevy 2wd, 5.3L)
    Obviously the fan shroud and clutch fan would have to be removed, but there would be:
    3/4-1/2" clearance between the end of the wastegate and the radiator core
    2 1/2" clearance between the down pipe and radiator core
    1 7/8" clearance between the wastegate pipe and radiator core
    On his truck I measured about 12" from the drivers side edge of the alt/ps bracket to the battery. My turbo setup sticks out about 5" from the edge of this bracket without the air filter. With the air filter it is about 12".
    The downpipe might work with a little modification where it approaches the firewall, but some of the heater hoses would definitely have to be rerouted based on what I saw on his truck.
    So overall I would say this should work on a NBS (99-06) GM fullsize truck with modification to the downpipe, heater and possibly a/c hoses and removing the stock fan setup. Additionally, his pcm was mounted next to the battery sort of above the frame rail. This might need to be moved a bit as well, but it depends on if you used the same airfilter or not.
    Hope this helps.
    91_bowtie Guest
    what do you want for thePT76GTSH?
    May 2007
    Las Vegas, NV
    Quote Originally Posted by 91_bowtie View Post
    I'll have to think about it, I'm not going to sell it separately just yet.
    May 2007
    Las Vegas, NV
    bump...lowered price $500
