Results 1 to 10 of 11
Thread: Turn signal problems!! "too fast??"
    Mar 2007
    Pittsburg, TX
    I recently tinted my rear tail lights, In order to be able to see them during the day I installed some led bulbs in them. The brake lights work perfectly, but when i use the turn signal the lights blink extreamly fast, but work as normal with regular bulbs. I got pulled over and was given a warning about the lights blinking too fast. So what can be done to slow down the turn signal speed.
    My Ride: 2006 Chevy Vortec Max, LQ9, 4X4, no cats, 50 Series Flowmaster in factory pipe, 20"s, C.A.I., Custom tune by Dustin at TRT Performance
    Spring, Texas
    Quote Originally Posted by 06BLACKMAX View Post
    They pulled you over for it blinking too fast?? That's just plain dumb! I guess that's what happens in the town of the Ezekiel Airship!! Sorry, I can't help you with your problem.
    Mar 2007
    Pittsburg, TX
    Thats nothing a buddy of mine got pulled over for excessive braking!!! The SOB's around here are the super cops of super cops.
    I thought blinking too fast meant you have a blown bulb.
    When I drove mine without the bed the signals went real fast.
    Spring, Texas
    That's the most ridiculous thing I've ever heard of. They must not have a lot to do if they are pulling people over for that!! Sorry to jack your thread.
    Mar 2007
    Pittsburg, TX
    Quote Originally Posted by ramair2002 View Post
    No problem.
    "I thought blinking too fast meant you have a blown bulb.
    When I drove mine without the bed the signals went real fast."
    Yes, that is true. But all of the lights are working. Just blinking really fast.
    Where is RedHeartbeat at when you need him??!!
    Nov 2006
    Cajun Country
    No problem.
    you are correct the lighting system is drawing (less) current and the truck does think a bulb is out, find a resistor
    go to Radio Shack and get the individual resistors.
    Remember to get the higher wattage resistors, so you don't smoke them
    DD: 2008 TB LS
    2005 Silverado VHO
    Well, you can either do resistors or just go ahead and load your blinker circuit with all LEDs. Since LEDs draw so much less current than regular incandescent bulbs, it tricks the blinker regulator into thinking that there is a bulb missing--hence not completing the circuit at the specific amperage. I put all LEDs in all blinker lights in my truck and it blinks normally--and looks badass too! I just don't like having to splice into the factory wiring harness to install resistors. You can do it either way---all LEDs or add resistors.
