We're current running a group purchase that covers 5 models of the Yank torque converters including the Truck Thruster line -
YANK TRUCK THRUSTER 2600 (4.8, 5.3L and 6.0) (278mm, 2600 stall, 2.10 STR)
YANK TRUCK THRUSTER 3000 (4.8, 5.3 and 6.0) (278 mm, 3000 stall, 2.21 STR, 98.6% efficiency!
YANK TRUCK THRUSTER 3200 (4.8, 5.3, and 6.0) (245mm, 3200 stall, 2.70 STR)
YANK TRUCK THRUSTER 2600HD (6.0 and 8.1L with 4L80E trans) (300mm, 2600 stall, 2.0 STR)
YANK TRUCK THRUSTER 3200HD (6.0 and 8.1L with 4L80E trans) (265mm, 3200 stall, 2.10 STR)
Due to Yank's guidelines I can't post pricing for the GP but you can receive a quote by giving us a call or e-mailing tbyrne@tbyrne.com.
10 or more orders are required by the closing date of Wednesday, February 4th for this GP to go through. Orders can be placed online or by calling 1-877-4-TBYRNE.
IMPORTANT INFO: Most products to fill each GP are ordered at the end of the GP. They usually take 1-2 weeks to ship from here, but some items could take longer based on the size of the group purchase and availability with the manufacturer. Depending on the product and our available stock, some orders will be shipped from here shortly after the GP comes to a close. Remember, you need to place your order if you are interested in taking part in a GP. Be sure to check the status of the GP that you are part of on it's closing date to see if is going through.
MORE IMPORTANT INFO: All credit cards are processed a few days before the GP closes to insure everything will go through without a problem and to lock in the order. Orders canceled after your GP order has been processed will be subject to a 10% processing fee. Orders for products that are non-stock items (not normally kept in stock) can not be canceled so be sure that you would like to be part of the GP before you place your order.
WHEN SHOULD YOU PLACE YOUR ORDER?: We find that alot of people wait for the required number of orders to be placed before they get in on the GP. If everyone does this the GP minimum is never met. If you would definitely like to join one of the group purchases that are listed it will be best to place your order as soon as possible. Your credit card won't be charged until just before the GP comes to a close (as long as there are enough orders) and the minimum will be met much sooner. This will allow you and the other participants to take advantage of the savings.
Have a good day,
Tom
- You may not post replies
- You may not edit your posts
