Results 1 to 6 of 6
Thread: '01 4.3 to '04 5.3
    Jan 2005
    DFW, TX - Autobahn Volkswagen Tech
    Ok so I found a 2004 5.3L engine complete with accessories, wiring harness, and PCM. My truck is a 2001 4.3L.
    What will need to be done as far as the anti-theft part of the PCM? I"ve read in a couple of threads that the newer models have anti-theft that needs to be flashed "out" of the PCM.
    Will this be an issue putting a '04 motor with anti-theft into a '01 truck with no anti-theft?
    Will the wiring harness from the '04 mate up with my '01 truck?
    Thanks in advance for any help you guys can give me.
    01 Silverado - 2004 5.3L Conversion from 4.3L V6 - Wheatley Tune - One Wheel Dance Off Champion
    http://shaggypokertables.com/images/sigblack.jpg
    NEED VW WORK OR PARTS? PM ME!
    mob-town
    You will have to get Vats disabled in the tune..
    Looking for a 05-07 Ext Cab or Crew Cab Chevy or GMC with some mods.. PM if you have anything
    thats the minimum of your worries...
    heres what you may have to consider:
    2004 system was fly-by-wire (so the 04 harness and computer are
    useless if you are looking to a straight across swap)
    so youll need either a 1999-2002 v8 harness (non fly-by-wire) or
    a stand-alone harness.
    if you use an OE harness youll have to repin your chassis/computer/
    fusebox outputs.
    fuel lines will need to be adapted or replaced for the v8 options.
    and yes tuning for VATS, speedo, and non-emissions compliance
    airdeano
    Jan 2005
    <div class='quotetop'>QUOTE(airdeano &#064; Apr 25 2007, 09&#58;50 PM) [snapback]91397[/snapback]</div>
    fusebox outputs.
    airdeano
    [/b]
    Thank you that was exactly the information I was looking for. I remember reading that somehwere but it was lodged in the back of my brain because I have been researching this for a long time. Looks like I need to keep looking for a 99-02 complete pull out. This guy only wants &#036;700 for the complete &#39;04 and it only has 24k miles on it. Maybe I should just get it because of the price and find a harness.
    Either way, thank you for the information. You possibly just saved me a lot of trouble.
    Oct 2005
    Baton Rouge, LA
    Why not buy it, and swap the TB for a cable-driven one? As far as wiring, what&#39;s wrong with custom harness? NP can hook that up for ya... not to mention a PCM tuned for a cable-driven powertrain.
    Is this not do-able? Am I thinking wishfully? I&#39;ve heard of people on PT swapping DBW TBs for cable-driven ones w/o issues. What&#39;s so different here?
    Test-n-Tune (Nov 23, 2008) - 13.65s @ 98mph
    Aug 2006
    LaCrosse, WI
    if all he wants is &#036;700, i&#39;d like to speak with him, thats almost too good of a deal to pass up
    '82 C-10......project truck.....
