Results 1 to 7 of 7
Thread: belt/alternator
    Jul 2005
    Loganville, GA
    hey im trying to change my belt in my truck and i need to know which size amp alternator i have to get the right belt, can anyone help me figure which amp model it is
    The amperage of the alternator is stamped into the housing if it's a genuine GM alternator.
    <div class='quotetop'>QUOTE(Z71sierra7787 &#064; Apr 16 2007, 09&#58;47 PM) [snapback]90138[/snapback]</div>
    If you can&#39;t find the amperage on the casing, take a ruler out to it and measure it---if the alternator case measures 5 3/8" in diameter, you have the 105 amp. If the alternator case measures 5 3/4" in diameter, then you&#39;ve got the 130 amp.
    Apr 2003
    Mansfield, Texas, USA
    Cool
    You have the 105A in your truck.
    Jul 2005
    Loganville, GA
    thanks for all the great help/advice as usaul
    Feb 2004
    Sour Lake Tx
    Take your belt to the store match it up and ask what alternator that belt is for, givng you your answer and drive home with the right belt. Put your old belt it the new belt sleeve write down what amp alternator you have on it and throw it behind the seat for an emergency. problem solved.
    EATIN' FORDS AND TUNDRAS
    Jul 2005
    Loganville, GA
    thanks for the help, i got it changed and put a gatorback on it but that wasnt the problem it was the 8 year old ac belt chirping so i replaced that too and the engine bay is now noise free, thanks again
