Results 1 to 10 of 13
Thread: painting truck with black primer
    Nov 2005
    so school is coming to an end and i have been thinking of all of the things i am going to do to my truck this summer...rear discs, flush tonneau, weld in rollpan and i think im going to just spray my truck with black can primer until i have the money to get it painted.. probably just flat black? what would be the cons of doing this and what do you guys think about the idea? thanks
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
    Mar 2006
    <div class='quotetop'>QUOTE(c1500 &#064; Apr 12 2007, 10&#58;47 PM) [snapback]89774[/snapback]</div>
    just my 2 cents but i say no no no....I am not sure what kind of body work you have done but you did say you were welding in the roll pan. So with that, primer is sorta like a sponge, it will absorb water and then you will see rust....then you will have to take all of that back off and treat the metal with some sort of etching primer or something. Another thing is that the cans of paint you will get arent good and if you plan on doing this thing nice with some good paint then all that you put on should definately come back off. All in all if you plan on driving your truck, leave that factory finish on it since it is a good protector and maybe consider just boltin your roll pan to it until you decide to paint then weld it in so it isnt weathered.
    I hope this helps,
    Jarrod
    after a few weeks the black primer will look like grey ash.
    Oct 2005
    Houston, Tx
    yeah i have always heard that about primer. it hold moisture. then you will have a bigger problem on your hands.
    Nov 2005
    thanks guys..
    Have you thought about just painting it with black basecoat? I wonder how that would stand up? I know the guys on Truckin painted their Old Skool truck with a black basecoat/clear that looks like black primer but it&#39;s sealed.
    May 2006
    Waco TX
    All you would have to do i think is get a basecoat black and add DX995. Its a flattening Agent and It would protect it from the sun and have no shine. No clear or anything has to be put on. DX995 will kind of mike the base coat singlestage.
    Made by PPG
    sprayed99 Guest
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Apr 13 2007, 03&#58;08 PM) [snapback]89841[/snapback]</div>
    Made by PPG
    From my experience I put the 995 in the clear coat and it flattens it and you will have a long lasting paint job and you can wet sand it and buff it. I have never added it to the base coat. The pic of the 32 prostreet ford we painted using the 995 in the clear. By the way the flames are taped on.
    DBYRD Guest
    <div class='quotetop'>QUOTE(sprayed99 &#064; Apr 13 2007, 11&#58;36 PM) [snapback]89911[/snapback]</div>
    looks like a sweet ride, nice paint work&#33; looks like u know what ur doing, wanna paint my rollpan and colormatch my stuff for me?
    Nov 2005
    well yeha i would do something like that for temporary until i could afford a paint job..how hard and how costly would it be for me to paint it with that base coat, or should i might as well just save up and get the color i want? or does anyone know of/ own a body shop that will cut me a really really good deal..
